2008 Fit leaky transmission
Old Dec 28, 2020 | 08:43 AM
dschmies's Avatar
I have a 2008 Fit 220,000 miles. Automatic transmission. The transmission continues to leak from the passenger side output shaft seal. A transmission shop installed a serviceable transmission about 6-8 months ago. It kept leaking and they replaced the seal twice. Still leaks and they are no help and obviously cant fix it. I suspected a worn CV axle and ordered one and another output shaft seal from RockAuto. I received the replacement and it does not include the whole assembly all the way into the transmission. I need the axle shaft I think as maybe it is worn on the seal surface. Has anyone seen this before? Has anyone replaced this part? Where can I get one?
from the transmission to the CV.
Old Dec 30, 2020 | 07:39 PM
tyrtill's Avatar
https://www.hondapartsonline.net/oem...QtYXV0b21hdGlj
Here is the intermediate shaft double check with your vin if possible
check for looseness in the carrier bearing because that could cause leaks if there is too much deflection and can be bought separately with some seals.
Old Jan 16, 2021 | 04:14 PM
winkybil's Avatar
I would check the pan or the seal around the driveshaft. These are the two most common leak causes and both should be fairly inexpensive to fix, albeit somewhat of a pain in the ass.
Kodi nox
TexasWonder
Dec 13, 2017 01:07 PM
Metafit
May 2, 2017 09:24 PM
GinoLicious
May 13, 2015 04:21 PM
WaterWatcher
May 4, 2005 11:16 AM
