Manual transmission not finding center
Old May 27, 2021 | 07:46 PM
boilup709's Avatar
I did some searching and couldn't find either thread.
The stick on my 2013 (79k km) is not centering when I bring it to the neutral position (sticks either left or right of center and I have to nudge it over) . I had the console apart and lubed the cable and shift mechanism but it's not really any better. Is there a thread someone can point me towards here or any advice? Would dirty (manual) transmission oil cause this?
Thanks!
Old May 27, 2021 | 10:14 PM
Pyts's Avatar
When you park it, do you leave it in gear? Maybe first gear?
I may be mistaken but I understand the stick to be centered by springs that can be worn out. said springs may be purchasable at a dealership, or if you have some money to spare you could upgrade to a short shifter.
Changing transmission fluid fully every 30k miles is a good idea also, or so I'm told
Old May 28, 2021 | 02:54 AM
howarejew's Avatar
check the centering spring on the left side of the shifter
Old May 28, 2021 | 02:51 PM
Azuki's Avatar
I think you guys are right about centering springs, I don't see an individual part for the spring though, there's a shifter assembly part 54100-TF0-013. I don't know if Acuity or anyone makes aftermarket springs
elkaku
BernardiParts.com
Oct 31, 2020 09:00 AM
robs
May 15, 2015 03:33 AM
n.phelge
Aug 27, 2013 12:29 AM
InigoMontoya
Mar 13, 2007 09:11 AM
Gordio
Apr 6, 2006 12:00 AM
