Clutch 90k
Old Oct 7, 2021 | 09:30 AM
cajunpedaler's Avatar
Clutch 90k
2013 fit manual transmission
no issues other than a slight lower to the floor to start the car.
doesn’t appear to be slipping or shuddering.
90k miles. Anything to be aware of.
im rural, so lots of highway miles. I’m a pretty aggressive driver, not wamby pamby.
Old Oct 7, 2021 | 06:57 PM
Pyts's Avatar
Mean you have to push the pedal down further to start the car? I think the only thing involved in how far the clutch pedal is depressed for ignition is a little safety switch down on the pedal's bracket. If we're talking about clutch wear, it's how far the pedal has to come up before engaging the flywheel. Down is pushing the two apart, n since the clutch disc isn't getting thicker/closer to the flywheel, I'm pretty sure you should have no trouble disengaging it unless there's some kinda mechanical failure in the clutch.
The Proper Fit
Feb 9, 2026 12:04 PM
Aaronbodywork@gmail.com
Nov 21, 2019 07:31 AM
rodney
Sep 2, 2014 07:28 PM
crxvfr
Aug 13, 2011 08:46 PM
ThePaulson
Nov 29, 2009 04:24 PM
