No radio, no dome lights, no door locks .....HELP
Old Jan 3, 2022 | 12:28 PM
Juuustpinnned's Avatar
So I killed my battery on my 09 and tried to jump it. I blew a fuse on the block on the battery post. Got a new block and now I have no radio ( no lights at all ) I open the door and there’s no power to the door locks and done light until I turn the key. Anyone have this issue?
Old Jan 3, 2022 | 01:33 PM
AirborneRATT's Avatar
My Dad did the exact same thing and had the exact same issue. After getting a new fuse block for the battery terminal for ~ $50, we took it to a garage which charged us half an hour to replace another fuse.
I assure you that it is a fuse near the main fuse block under the left side dash. The mechanic said that it was a separate fuse box and was behind(?) the main fuse box? I'm not sure what he meant but it was a simple fuse.
Old Jan 3, 2022 | 04:55 PM
yeah I’ve tried ever signal fuse.
Old Jan 3, 2022 | 07:13 PM
Nope. It's not in the main fuse box. I had that trouble too. That's when I had to take it to a mechanic. It is a fuse I promise. I wish I could better point you to the exact location of it.
Old Jan 3, 2022 | 08:06 PM
FOUND IT. So if you look on the schematics the first small fuse that’s labeled “ Back up”
I assumed it meant back up fuse like as in spare. Wrong it’s the fuse they pull for shipping across over seas. It kills the anti thief system and the red flashing light on the stereo. This way it doesn’t kill the battery. ....... so I’m told.
Old Jan 4, 2022 | 09:23 AM
Awesome and thank you for the clarification.
Old Feb 27, 2024 | 10:18 PM
Ajl80's Avatar
I was going nuts
It is listed as back up. 10amp 1st fuse changed 10 other fuses
Old Feb 15, 2025 | 05:19 AM
salim.fendri's Avatar
had same problem
I had same problem and it was a fuse. I just wanted to add picture to better show the exact fuse. it's the 10A red fuse marked in red in the top left corner.
AirborneRATT
Dec 27, 2020 09:37 PM
BankWalker
Dec 22, 2015 09:18 PM
davidteddiilin
Oct 16, 2014 05:12 AM
VerbalJungleGym
May 21, 2009 11:39 PM
dbcmaster
Apr 11, 2008 02:51 PM
