Radiator longevity
Old Jan 18, 2022 | 08:11 PM
tbearfit's Avatar
Radiator longevity
Just wondering how long radiators tend to last? My '09 has 177k and original rad so wondering if it's something for a Spring project?
Old Jan 18, 2022 | 09:32 PM
GAFIT's Avatar
No need to replace unless it's leaking. Even if the car has an overheating issue, I'd suspect the thermostat or water pump first.
Old Jan 18, 2022 | 09:34 PM
tbearfit's Avatar
Actually, I have those sitting in the garage in case they are ever needed. Water pump looks dry but original - not sure about thermostat. May do them whenever I change out the coolant.
Old Jan 18, 2022 | 09:54 PM
GAFIT's Avatar
Coolant change is a good idea. Other stuff...I'd just wait till they are needed. Especially if you're replacing with aftermarket. The old OEM Honda stuff is probably better than new aftermarket.
Old Jan 19, 2022 | 07:27 AM
tbearfit's Avatar
Maybe - I tend to buy the "OEM" brand aftermarket like Denso, NTK, etc. The water pump is Aisin. May change the thermostat when I change the fluid since it's pretty simple.
Old Jan 19, 2022 | 10:54 AM
Mister Coffee's Avatar
Change the coolant fluid at least every 3 years. Use Honda (or a proper) coolant and distilled water. I'm pretty sure that that is the key to long radiator life.
Old Jan 19, 2022 | 11:16 AM
tbearfit's Avatar
I can't wait to see what comes out when I drain it. The transmission fluid is still brown after the second drain/fill.
justus
Mar 8, 2021 05:17 AM
john21031
Nov 26, 2015 01:39 AM
Bugzs15
Nov 5, 2013 06:57 PM
thedeadpoet000
Feb 27, 2013 08:14 PM
Oofie
Jun 18, 2011 05:50 PM
