Window won’t roll back up
Old Feb 16, 2022 | 02:12 PM
vang's Avatar
My passenger window will only go down and won’t go up. Both main and passenger switches work when pressing down but both won’t work going up. I installed a new window regulator and working rear passenger switch and it still does the same thing. Any suggestions?
Old Feb 16, 2022 | 04:17 PM
Frenzal's Avatar
Maybe your main switch?
Don't know if it is the same on the Fit, but on an older Civic, the signal would go to the main switch, then passenger switch. So if you have a problem with the main switch, it won't word either from the passenger switch.
Might not be the same on the Fit though.
Old Feb 24, 2022 | 12:33 PM
vang's Avatar
new main switch fixed the issue. Thanks!
Old Dec 14, 2022 | 02:47 AM
Chinasongz's Avatar
Main switch part number
Is there a part number for this main switch please? My boyfriend rolled my windows down and now it won’t come back up. Passenger side.
Old Jan 4, 2023 | 11:45 AM
pthompso99@yahoo.com's Avatar
Old "solution"
Turn off engine. Go outside door. Slam it really hard. Turn on engine to widoww setting. Only works once or twice so get repaired soon.
runbikerun
Apr 17, 2023 08:57 AM
patm95
Jun 22, 2016 11:36 AM
Battleendless
Toronto Community
Jan 10, 2008 05:09 PM
Raaaaaaaaaay.
Nov 26, 2007 06:10 PM
cityfit
Aug 26, 2007 05:26 AM
