Best Tires for 2009 Fit
Old Apr 17, 2022 | 03:05 PM
outoforder's Avatar
Just bought a 2009 Honda Fit with 164,000 miles. Car has a cheap set of tires on it and rides a bit rough. I feel every bump in the road. What is the best tire to get to improve road feel of the car? I’m using the car to get back and forth to work 40 miles a day on the highway. Not worried about performance, just need comfort.
Old Apr 17, 2022 | 11:43 PM
Red 05's Avatar
You aren't going to find comfort. I've gone so far as to go down an inch to 15 inch wheels and tires for a taller sidewall, doesn't make an appreciable difference. Nor do a different set of struts because most all sold for the Fit are stiffer and valved for harder springs.
Old Apr 18, 2022 | 01:44 PM
56chevydan's Avatar
Go to Tirerack.com and compare tires yourself. Then look for feedback posts there on the tires from members that have run them.
Remember that tires that are highly rated in California won't necessarily be the right tire for you in Ohio.
If it gets too confusing, call Tirerack and speak to a salesman. I've had great help from a salesman by the name of Walt there.
Good luck with your selection.
Old Apr 19, 2022 | 06:34 PM
Pyts's Avatar
I'd suggest checking tire pressure if you haven't yet. Options outside of the 15" wheels would be.. air suspension which I know nothing about, or springs with progressive spring rates.
Tirerack is an awesome resource and I hope they stay in business. If there's any kind of wizardry that could be achieved with tires, those would be the guys to ask.
Old Apr 21, 2022 | 07:24 AM
outoforder's Avatar
Thank you for the information. What is the tallest sidewall I can get in a 16in wheel? Book says 55R. Can I do a 60R without rubbing?
Old Apr 21, 2022 | 10:54 AM
AirborneRATT's Avatar
I selected tires based on longevity (how many miles they should last) economy (how easy they roll down the road and increase my fuel efficiency) and low noise.
https://www.tirerack.com/tires/tires...toModClar=Base
These are the tires I have and I like them a lot.
Old Apr 22, 2022 | 10:24 AM
SavvyFit's Avatar
A Fit on bags. If that doesn’t get you street cred idk what will.
Idir Mahrouche
Sep 23, 2021 10:37 AM
shack22
Mar 22, 2020 08:11 AM
taylbf31
Jul 5, 2013 09:34 AM
MugenAP2
Florida Community
Aug 2, 2010 11:32 PM
JagsFIT
Apr 10, 2009 12:48 AM
