RCA cable wiring for backup camera
Old May 1, 2022 | 04:44 PM
Idir Mahrouche's Avatar
Hello,
im struggling to get the rca cable through the rubber cable covers in behind. I’m using a hanger to fish it through. I can’t. What would you suggest?
Old May 1, 2022 | 06:48 PM
howarejew's Avatar
Lube with silicone. Or cut the plug, thread the wire through and reattach the plug.
Old May 2, 2022 | 08:37 AM
Ultrawolf's Avatar
You can get RCA to 2.5mm and 3.5 mm mono cables and adapters. The mono plugs are a little smaller than RCA, so you might be able to fish a cable with those ends through, then use adapters at the end to go back to RCA. Amazon has many.
Old May 2, 2022 | 04:59 PM
I did it in under 30 seconds with a silicon lube. Thanks a lot.
GER42
Jul 31, 2021 11:01 PM
SilverEX15
Dec 16, 2017 05:46 PM
SilverEX15
Oct 1, 2015 04:40 PM
c3kay
Mar 12, 2015 05:53 PM
goConcrcete
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Jul 12, 2014 04:02 PM
