2011 Auto Sport whining sound
Old Aug 15, 2022 | 01:20 PM
Sleep4Ever's Avatar
2011 Automatic Sport makes a cycling whining noise when slowing down. Once the speed drops to 20, you here it whine with the pitch going down, then at about 15, it repeats again. Using the paddle shifters, I have gone up and down through the gears while slowing down and the change of gears does not change the sound. Transmission fluid is full and pink. Cannot replicate the sound in neutral. Is this normal engine noise or something else?
Old Aug 16, 2022 | 06:57 PM
Pyts's Avatar
If you're confident that the fault is directly associated with vehicle speeds and is unaffected by rpm/gear then you can limit your search area to the CV shafts, brakes/rotors, wheel bearings, and tires. I'm pretty sure that's it unless you think it's a wind thing.
​​​​​​Do any of those sound likely?
Old Oct 7, 2022 | 02:24 PM
duanemunroe_2000's Avatar
Did you get this sorted out?
Imjusthereforadvice
Jan 21, 2019 12:23 AM
nodelock
Oct 25, 2012 05:43 AM
ltd
May 25, 2012 08:24 AM
tigerseye1108
Feb 10, 2010 01:44 AM
tigerseye1108
Feb 8, 2010 08:14 PM
