Disable Automatic AC on defrost?
Old Feb 8, 2023 | 07:07 AM
surly's Avatar
UPDATE:
It's a late update, since this work was done in December, but I realized I did not write back.
By removing the plastic cover plate (with the interior LED) under the climate control, and accessing the rear of the panel from the glove box area (after swinging the glove box down out of the way), I was eventually able to slide the connector pictured above off of the back of the HVAC controls and disable the automatic AC function entirely. It works perfectly and I'm happy it was so simple.
While a simple process to describe, I had far more trouble physically accessing the area in question behind the dash than various videos seem to illustrate. The spaces were all smaller than they looked online (e.g. I couldn't even get a finger to the same spot where one person had filmed themselves touching and wiggling a component with their fingers) and I don't have huge hands. At the same time I also had to pull the rear defogger switch and replace the switch illumination bulb. It was handy that both jobs were in the same spot.
Old Sep 25, 2024 | 03:10 PM
Jack2024's Avatar
The ac defroster switch
This job was a bit more technical than I would have liked. Remove all the dash components to get the the temperature control system. Take the temperature control knob off using the Philips screws on the back. Do the same for the vent selector knob. Locate the switch in the photos. Good luck!
Bottom left corner of the vent selector
Top left view of switch with wire clip (top) and the switch (lower) circled and switch bolts with arrows
Lower view of disconnected switch and arrows to the bolts
htewam
Sep 25, 2024 03:26 PM
Limmie
Aug 28, 2021 11:04 PM
Roger's Fit
May 28, 2021 11:55 AM
billtmore
Jul 20, 2017 10:30 AM
stickyricebandit
Jul 22, 2008 08:41 PM
