Engine oil
Old Jan 22, 2023 | 07:28 PM
simo's Avatar
Engine oil
Hi
I have a 2013 Honda Fit 1.5 litre XS what is the correct engine oil to use ,it seems everywhere i ask they give me a different answer even Honda garages here in New Zealand.
cheers
Old Jan 23, 2023 | 04:09 AM
Red 05's Avatar
It should say on the oil fill cap.
Old Jan 23, 2023 | 12:54 PM
56chevydan's Avatar
Are you asking what viscosity oil to use, or synthetic vs. conventional oil?
If you're asking about the viscosity of the oil, as Red 05 said, it's printed on your oil fill cap on top of the engine in the valve cover. It's also printed in your glovebox owner's manual. Honda makes a recommendation and it's further based on average climate temps where the vehicle is operated. My car shows 0/20 weight. The oil acts as a 0 weight oil when the car is started (cold), and then acts as a 20 weight oil when the engine is at operating temp (hot). Extremely cold temperatures, or extremely hot climate temps will necessitate using other weights of motor oil.
If you're talking conventional motor oil vs synthetic motor oil- that's a personal choice you can make after Googling the differences in the oils. I personally use a full synthetic motor oil in my car.
ababinili
Jul 9, 2021 07:16 PM
hondaria
Dec 9, 2019 04:58 PM
Austinite
Jun 3, 2014 10:10 PM
hondafit_03
Aug 13, 2011 11:05 PM
KnifeEdge_2K1
Feb 19, 2007 01:29 AM
