Help. Passenger front window won't close, but will open only on passenger switch
Old Apr 9, 2023 | 12:25 AM
tirk82's Avatar
Hi 👋 . I have a 2013 Honda Fit. My issue is the passenger window will not close (go up). It will, however, open (go down) from the passenger switch , but won't open or close on the main switch. I am able to close the passenger window by jumping the passenger side using the paperclip method (after unplugging it from the switch) so the motor definitely works. I already replaced the main control switch and that did not solve the problem. Any guidance would be very much appreciated.
Old Apr 19, 2023 | 01:04 AM
2015LXFIT's Avatar
Wiring Diagram
Per this diagram you need to run a continuity check on the wires from the master switch to the motor itself. Keep in mind you will have to actuate or "close" the switch in order to perform this properly. I'm leaning heavily towards some sort of issue with the passenger switch but I'd start on the harness first. Good luck.
Old May 30, 2023 | 12:34 AM
whitege's Avatar
I had this issue, but i could also bring down the passenger window from both passenger's and the driver's sides. I replaced the driver's side switch unit and it worked.
vang
Jan 4, 2023 11:45 AM
btoad
Aug 1, 2016 04:22 PM
Santiad
Dec 8, 2015 08:48 AM
Body2Big
Jun 16, 2014 03:14 PM
Satchel
Jan 23, 2009 03:47 PM
