Electrical issues (Radio)
Old Apr 12, 2023 | 08:04 AM
Shanuzal's Avatar
Hi everyone!
​​​​​​I have a 2011 Honda fit. It was jumpstarted with the cables on the wrong terminals.
This blew my main battery fuse. I replaced that and my car started.
Then my key lock, radio, and dome lights were not working. I checked the fuses and replaced the Back Up fuse. My key lock and dome lights work now but my radio is still not turning on.
I believe the radio has power. I have a nav system and the open button will move the screen, but it will not power on.
I'm looking for advice on what other connections or fuses I can check to fix my radio.
Old Apr 19, 2023 | 12:54 AM
2015LXFIT's Avatar
I'd just check continuity on literally every fuse and then swap relays for related components. If that doesn't work, I'd assume a new unit is in order. I've seen someone jump a vehicle backwards before and it fried the ECM, BCM, and a few other things. That was a Ford though.
Old Apr 19, 2023 | 06:25 AM
Shanuzal's Avatar
Thanks for the advice! I actually figured this out yesterday. It was fuse 61 for the radio, which I had a hard time locating.. and it was empty. Not sure what happened. I put a fuse in there and everything worked fine.
Billy Fit
Oct 21, 2022 12:44 AM
SubaruSlayer
Mar 26, 2019 09:25 AM
Fit freak242
Nov 6, 2013 10:44 PM
TrippKnightly
Aug 12, 2012 03:50 PM
STOCKTREK
Jul 25, 2011 06:09 AM
