What’s that cone air filter thing
Old Apr 12, 2023 | 05:55 PM
Kirbytrainnerd's Avatar
I founded this from a video and saw this
Old Apr 12, 2023 | 07:02 PM
I know about the breather filter but don’t know about the blue thing
Old Apr 13, 2023 | 10:25 AM
Pyts's Avatar
That's.. my car I think. it's a knock-off t-rev. secondary pcv valve purposed for creating negative crankcase pressure. I don't recall making a video but.. thats my mounting location, colors, hose clamps, ect.
Old Apr 17, 2023 | 12:11 AM
mykizism's Avatar
Is your car blue?
Old Apr 17, 2023 | 12:41 AM
Pyts's Avatar
take a guess!
Old Apr 18, 2023 | 07:24 AM
jonshonda's Avatar
What did you accomplish by adding this system?
Old Apr 18, 2023 | 11:51 AM
Pyts's Avatar
no oil in throttlebody, feel akin to, i'm told, a lightened flywheel.
It reduces the amount of engine braking that takes place when the clutch is disengaged during shifting.
Don't jump on me for a misstep in speaking here I'm sensitive about my mod - which lacks a measured or explained performance descrip. from the manufacturer.
Old Apr 19, 2023 | 06:03 AM
jonshonda's Avatar
I will have to look more closely at the PVC routing, but are you sure the outlet for the PVC is upstream from the throttle body? I understand the principals behind the mod, and agree that drawing a slight vacuum (aka neg pressure) can help reduce back pressure and pumping losses. I was just curious if you noticed anything as the mod is likely much more effective during extreme (racing) conditions.
The EPA mandates a lot of things that likely cut down on engine longevity and performance, so I don't doubt that there are some mods out there that the EPA might not be fond of, but work well to improve performance.
Old Apr 19, 2023 | 12:11 PM
Pyts's Avatar
It came with specific instructions to use a separate pcv line from the one the factory valve is in. Taps into the one that goes to the airbox. I'll post up two or three pictures showing routing.
I didn't find any claims about a cleaner throttle body, and it wasn't something I was l was looking for. Really I'm unsure if that's a benefit, because I'm pretty sure it means all the blow-by gook stays in the oil. That would probably be a pro if I increased frequency of my oil services.
The other negative I see for this device is the junky little air filter, but man, I shopped and shopped for a higher quality one.
With regards to effects, I do notice a stark difference every time I press the clutch pedal down, as well as when I let off the throttle fully while in gear - moreso at higher rpms.
​​​​​​If not for that, I would have chucked the thing under the premise that I don't know whether I'm doing harm or good.
Old Apr 20, 2023 | 08:24 PM
Pyts's Avatar
Amatuer hour! Subject: hose routing.
First time soldering copper pipe. painted it black, only thing that sucked besides my work was fitting it into the rubber grommet on the air box. I'd love to find another grommet but don't know the nomenclature to look one up.
just goes from the valve cover to the valve, to the air box.
Old Apr 21, 2023 | 12:07 PM
jonshonda's Avatar
^Nice! Very interesting there is that much pressure in the engine under normal operating conditions. There are many claims of 3-4% pump in power due to the gain in efficiency. Thanks for sharing.
gciocco
16
Aug 8, 2022 07:05 PM
Idir Mahrouche
Jul 30, 2022 09:56 AM
Chitown Fit
Apr 7, 2019 01:52 AM
Odie
Nov 1, 2017 04:02 PM
bigsmitty
Jul 14, 2017 07:17 PM
