2013 Honda Fit Sport Rattle
Old Jul 10, 2023 | 02:15 PM
Kxbronco's Avatar
I’ve been trying to find the rattle in my Fit for a long time. Watch and more importantly listen to the video. It sounds like it’s coming from the front of the vehicle. The road is pretty good with mostly cracks in the pavement. I do tow this car behind my motorhome. If tried the following with no luck:
  1. put pipe insulation/foam around anything I can find that might rattle and drove around
  2. checked tow bar baseplate bolts and they are tight and drove around
  3. removed the front end/bumper cover and drove around
  4. removed all plastic covers from underneath and drove around
  5. Removed side ground effects (not sure what they’re called) and drove around
  6. checked top front strut mounts, they were tight, and drove around
  7. Lastly, completely removed sway bar end links, put pipe insulation around sway bar and drove around
Any thoughts as to what might be rattling? It does seem to be getting worse so I’m thinking it’s a wear type problem.
File Type: mov
Old Jul 10, 2023 | 02:23 PM
Kxbronco's Avatar
Trying to upload the video but I keep getting an Alert indicating data not processed.
15:45 ET - after starting with a file at 20mb and couldn't upload and then it started saying it couldn't be over 5mb, I got the file whittled down to 4.5mb and it still says the file/data can't be processed. Is there a trick to uploading a file? I'm using the mange attachments functionality.
Old Jul 12, 2023 | 08:45 PM
Kxbronco's Avatar
It might have worked this time! Looks like you will have to download it to see it.
Any thoughts or input will be much appreciated.
File Type: mov
harryk
Mar 26, 2022 02:35 PM
chrisw_lfp
Aug 7, 2017 04:41 PM
Bbirdman
Texas Community
Jan 17, 2017 10:57 AM
JVH
Jul 19, 2011 08:22 PM
AnlDyxp_GD3
18
Nov 3, 2008 07:56 PM
