Intermittent clunk-end front
Old Mar 23, 2022 | 06:08 PM
harryk's Avatar
Question Intermittent clunk-end front
I'm having a problem with a loud clunk in the front of my 2015 Fit. A mechanic put it on the lift. He pried, wiggled inspected the front suspension, but could not find anything definite. Th "clunk" does not effect the steering or the operation of the car - just an annoying clunk.
He said he could start throwing parts at it, but with no guarantee of a fix.
My Fit has 62000 miles and was an early Gen 3. I actually bought it in late 2014. Love the car otherwise - some problems early, but very little problems until now. Any suggestions?
Old Mar 25, 2022 | 02:24 PM
PeaBrainer's Avatar
Does it generally happen when you go over bumps?
if so, I suspect is the anti roll bar drop links.
Old Mar 25, 2022 | 04:57 PM
harryk's Avatar
Thanks for replying, Peter
It does get much worse when I travel on rougher roads. so I will pursue that possibility.
Are "the roll bar drop links" the same as the "sway bar end links"?
Thanks again
Harry
Old Mar 26, 2022 | 08:09 AM
PeaBrainer's Avatar
Yes its the same thing as sway bar end links.
They are inexpensive to replace, I would do both side.
Old Mar 26, 2022 | 02:35 PM
GrE8_Fit's Avatar
You can disconnect the end links completely and test drive it to determine if they are the the problem before you buy new ones.
GBR
3rd Generation GK Specific Suspension & Brakes Sub-Forum
Jun 20, 2019 05:11 PM
azopelnut
Aug 20, 2018 09:49 PM
DamFit
Sep 27, 2017 06:24 AM
NutFit54
Nov 30, 2016 02:59 PM
startroops
Sep 12, 2007 01:44 PM
