No radiator fans no ac please help
Old Sep 24, 2023 | 01:52 PM
dosuna's Avatar
I have a 2009 Honda fit sport I am having some issues now after I adjusted my driver side power mirror my radiator fans and ac stoped working on me. I have since change out all my relays under the hood and under the dash I have also replaced almost all my fuses in the fuse panel, the fuses on my battery terminal are not blown I have replaced my blower motor and resister and got a new battery. I’m in the process of getting a new master control switch for the drivers side door. Anyone with any info on what else I need to do or check or replace to get my car on the road again please help!
Old Sep 28, 2023 | 01:50 PM
claycolvin's Avatar
No fan
I don't think the door controls should effect the fans. Check the power supply to each of the fans. Getting voltage to the fans? First thing to check after fuses and relays. The fan relays are under the battery in case you did't know that. Best of luck.
Old Sep 28, 2023 | 01:53 PM
claycolvin's Avatar
No fan
Why did you replace the blower motor and resistor? Not related to radiator fans. You need the radiator fans to work for the AC to work. Do you have a multimeter? The ground wires must be checked too. One wire is hot and the other is a ground. The electrons move from power to ground. The fans just draws current if operating. Best of luck.
gilles_o99
Jan 14, 2021 02:44 PM
mailtoome1
Nov 16, 2019 07:50 AM
KippoSleek
Jul 21, 2019 10:50 AM
Jpo805
Apr 5, 2019 03:11 PM
igoodtoo
Aug 7, 2005 12:31 AM
