Radiator fan switch
Old Jan 11, 2024 | 06:06 PM
Eriksen's Avatar
Radiator fan switch
Have a honda jazz year 2013 that got hot and leaking in the radiator, replaced the radiator and thermostat, but the radiator fan does not work? and I can't find the location of the cooler fan switch, is it the one at the bottom of the cooler?
Old Jan 13, 2024 | 03:11 PM
claycolvin's Avatar
Fan relays
The fan relays are in a black box under the battery (not under but near the bottom). The ac relay is also there. Clay
Old Jan 13, 2024 | 04:24 PM
Eriksen's Avatar
I have found the relay for both fans under the battery, but are there sensors other than the one at the bottom of the cooler/radiator that causes the fans to start?
Thank you Best regards Erik.
Old Jan 13, 2024 | 07:05 PM
56chevydan's Avatar
The "base" fan is engine temperature controlled and is automatically turned on at a set temp..The secondary a/c fan comes on and is controlled when the a/c is turned on.
There is more info available on the downloaded factory shop manual on this site.
Old Jan 15, 2024 | 04:46 PM
SiXiam's Avatar
This confused me also. Thought my car was also broken when I first got it.
gerard6496
Jan 12, 2024 02:12 AM
Enigmatic_1
May 9, 2019 09:17 AM
mangosmoody
Jun 19, 2016 07:38 PM
Al Davis
May 15, 2005 07:30 PM
