Weird back and forth rubbing sound when braking
Old Feb 28, 2024 | 04:59 AM
Nowarexx's Avatar
Hey there.
I have a '09 MT Fit/Jazz (GG3). Yesterday, when I arrived home, I have noticed a strange sound from somewhere in the engine bay. I was braking while in gear, and without the engaged clutch, and a weird repeating back and forth rubbing sound has appeared. When I engaged the clucth and slowed down, the sound disappeared.
Since then, I drove it to find out what could be wrong, and I have noticed, that this sound only appears between 10-50kph (6-31mph), in all gears, also when in neutral it happens too, but just only when braking. Sometimes, engaging the clucth makes the sound disappear, but 1 in 10 cases, the sound is still there.
I have briefly checked my brakes, but I have not found anything wrong.
The only recent change regarding the car is that 1 week ago, the I have noticed the wear on the clutch, because it engages closer to the upper end than before, but it is still okay I think.
Has anyone heard about a case like this? If so, what could be the cause? Should I take it to a mechanic?
Thank you in advance.
edit:
I drove it again today, and what I wrote before is not really the case. I have found out, that the clutch has nothing to do with this, because the weird sound only appears when I slightly press the brake pedal (like when you are getting close to a turn and you have to slow down a bit), and if I start to press it even more or stop pressing it, the sound disappears.
Also, the sound comes from the area of passenger’s side front brakes, and only when I am slowing down from 30kph (18mph) to 0.
At the weekend, I will take off that wheel and inspect the brake.
But I am still looking for ideas about what this weird sound could be, because I would like to repair it!
Old Feb 28, 2024 | 01:28 PM
56chevydan's Avatar
On your front brake pads, Honda engineered a thin metal shim that attaches to one front pad on each side and runs perpindicular to the rotor and is about 20% the thickness of new pads. The shims are designed to touch and rub on the brake rotor when the pads are worn down to around their last 20% of thixkness to remind the driver that the brake pads will soon need to be serviced/ replaced. This sounds like the problem you're describing.
If this turns out to be a solution to your problem, it would be appreciated that you post again that this solved the problem. This feedbacl helps the community here.
Old Mar 3, 2024 | 04:15 AM
Nowarexx's Avatar
Dear Chevydan,
This turned out to be the case, after inspecting it i have seen the mentioned shim. Thank you, I was really worried about the brakes, but it seems that I just have to change them. Thank you again!
abhijith
Jan 27, 2024 11:46 AM
Danny1997
Mar 8, 2023 03:58 PM
allie_kat18
Oct 15, 2021 02:09 PM
ltd
May 25, 2012 08:24 AM
stlfit
Dec 6, 2008 08:16 AM
