2010 fit electric power steering questions?
Old May 26, 2024 | 11:04 PM
rshimizu12's Avatar
I finally solved the low charging problem...!! Turned out that a ground was not connected. The electrical steering problem happened at the same time. The TPMS light is on and EPS is not working at all. This leads me to believe that it is a EPS programming issue. Now there is EPS fuse on my fit. My other question is what symptoms.are their that the EPS.module needs reprogrammimg.y other question is if there is another device that can be used to re-program the EPS module besides the Honda's DTSI software...? Also wondering what the recommended method for resetting the Honda EPS module. Now there is generic method that says to completely drain the battery & reconnect it after.a few.minutes. I had a dead battery & took it out to charge it. So doubt this will work. If not going to run some diagnostics.
  1. Trouble codes
    1. B1173 Gauge control module: lost communication with TPMS
    2. 71-01 Motor angle sensor
Storeyburn
Dec 5, 2023 12:32 AM
johnny dakota
Nov 28, 2023 11:38 AM
chocker
Dec 20, 2021 03:16 PM
1toughfit
Nov 23, 2015 07:30 PM
mzpinetree
Oct 19, 2011 03:56 PM
