Tpms calibration
Old Apr 8, 2025 | 10:31 AM
ramondo's Avatar
Tpms calibration
How do you calibrate tpms on 2013 fit sport with digital display. No calibrate button.
Old Apr 11, 2025 | 06:35 AM
Red 05's Avatar
There is no calibration process available to the end user. I think with a Honda scan tool the psi range it looks for can be changed but there's no real reason to do it since it's such a broad range anyway.
Old Apr 11, 2025 | 01:06 PM
bobski's Avatar
Wheel pressure sensors sometimes calibrate to a standard value (such as sea level air pressure and 22°C/72°F room temperature) when their battery is replaced.
Old Apr 14, 2025 | 08:08 PM
ramondo's Avatar
What does the calibrate button do on vehicles without the digital display (some members have mentioned the button at lower left on dash i have seen photos of said button but cannot find any info ) I had the low tire pressure light com on after a cool night but the tire pressure was 34 psi. I increased pressure to 37 psi drove for a while then light went out. Could this be a symptom of low battery in the inwheel sensor and if so how easy are they to replace?
Old Apr 14, 2025 | 08:38 PM
bobski's Avatar
Some TPMS systems don't have pressure sensors at all. Instead, the Traction Control System / Vehicle Stability Assist unit watches the rotating speed of each wheel very closely - it already has a high-precision speed sensor at each wheel for detecting traction issues. A properly inflated tire stretches slightly, giving it a larger rolling diameter and circumference, meaning fewer wheel rotations to cover a given mile, blah blah and so on. If one wheel is turning slightly faster than the others, the TCS/VSA unit concludes that tire could have low air pressure, and triggers the warning light.
The thing is, tire air pressure isn't the only thing that affects wheel diameter. Normal tread wear can affect wheel diameter just as much (if not more) than air pressure. Abnormal wear on one tire due to a suspension/alignment issue could set it off. If tires don't get replaced in complete sets or you're driving on the spare tire, that could confuse a wheel-speed-based TPMS system. In that case, the calibrate command tells the TCS/VSA unit "everything is okay, this is the new normal". The system then samples the wheel speeds during straight-line travel, stores those as the baseline "normal" and starts looking for new deviations that could indicate an actual problem.
Old Apr 15, 2025 | 05:10 AM
Frenzal's Avatar
Don't think the Fit has indirect TPMS...
Old Apr 15, 2025 | 10:11 AM
bobski's Avatar
3rd gen Fits do.
Old Apr 15, 2025 | 12:42 PM
Frenzal's Avatar
Originally Posted by bobski
3rd gen Fits do.
Didn't know that! Great!
But in Canada, none 2nd gen Fits have them. Don't know about 3rd gen...
oskie
Jul 11, 2023 12:32 PM
JCLW
Apr 29, 2020 02:56 AM
fritz269
Jul 21, 2016 12:16 AM
Jfit13
Mar 2, 2013 12:32 PM
Bustov
Feb 25, 2009 01:40 PM
