TPMS light won't turn off.
Old Jul 9, 2023 | 10:04 PM
oskie's Avatar
I changed the instrument cluster on my 2007 Honda Fit since the old one crapped out. I made sure the part numbers were the same and now the TPMS light is on. I looked up how to reset it but I don't have the button on the left side of the steering wheel its only on 08 and up models. Any advice would be greatly appreciated.
Old Jul 10, 2023 | 11:11 AM
derykisonder's Avatar
Try checking your tire pressure first. If all are good then maybe one of your tpms sensor is bad?
Old Jul 10, 2023 | 11:55 AM
oskie's Avatar
I believe the 07 models don't come with it. I checked and it's just the regular valve stems on the wheels.
Old Jul 11, 2023 | 12:08 AM
Hootie's Avatar
2007s don't have TPMS, 2008s do have TPMS as a model year mandate per the government.
From 2008 to 2013, Fits used a direct TPMS which used actual sensors in the wheel. The indirect method seen on GK5s (2015 to 2020) will not apply.
You likely snagged a gauge cluster out of a 2008... Not sure how the TPMS fault would prompt unless it was stored from the previous car or the gauge control module sees the lack of the TPMS wiring as a system fault.
Old Jul 11, 2023 | 12:19 AM
oskie's Avatar
Makes sense. I checked and it's indeed from a 2008. Hopefully that's okay it's working so far.
Old Jul 11, 2023 | 01:04 AM
Hootie's Avatar
Should be fine other than the TPMS light throwing a fit.
Yeah... I said it. Hehe
Old Jul 11, 2023 | 12:32 PM
oskie's Avatar
Hahaha good one 🤣
bendeezie
Arkansas Community
Feb 8, 2023 09:53 AM
Phoebe70
Jul 15, 2015 05:54 PM
Sloto200
Mar 28, 2015 09:50 PM
Ron Belisle
Mar 22, 2015 07:58 PM
jetscream
Jul 25, 2008 12:16 AM
