Possibly clutch problems
Old Apr 10, 2025 | 01:38 AM
Ismael33's Avatar
Need help diagnosing a problem on my Honda before I go ahead and remove the transmission for a possible bad clutch. Problem occurred when I downshifted to over take a car and came up to a stop light and car didn’t wanna move after that. Car just revs up while in gear.Goes into all gears fine,when releasing the clutch while in gear car won’t stall out, also moves slowly in reverse and moves slowly in 1(could push the car faster tbh). Anyone have any suggestions on what could be the problem?
Old Apr 10, 2025 | 09:30 AM
Drew21's Avatar
I think you have made the correct conclusion. All of your symptoms fit a failed clutch.
If you're pulling the transmission to do the clutch, educate yourself about other parts you may want to replace at the same time, including the pilot bearing, throw-out bearing, and (depending on your mileage or if there is any sign of weeping oil) rear main seal.
Old Apr 10, 2025 | 11:57 AM
Mister Coffee's Avatar
@Drew21 Do we have a DIY that includes your recommendation to replace the "other parts"?
Old Apr 10, 2025 | 03:52 PM
GrE8_Fit's Avatar
I keep watching this. Maybe one day I'll psych myself up and do it.
Old Apr 11, 2025 | 04:43 PM
Alexander Chernoch's Avatar
I've replaced my clutch in the past on my Fit. I recommend having the weekend free to get 'er done and a friend to help out. I used the Exedy HCK1010 OEM Clutch Kit from Amazon. car still runs great.
Aaronbodywork@gmail.com
Nov 21, 2019 07:31 AM
TOORAPH
Sep 12, 2015 01:36 AM
SammiJo
Jul 25, 2012 06:59 PM
radfit
May 11, 2012 11:54 PM
Sk8rgrrl22
May 4, 2005 11:16 AM
