AC only cold at high RPM
Old May 10, 2025 | 11:18 PM
raysigh's Avatar
So I’ve ruled out a bunch of issues: compressor clutch relay has been replaced. All fuses are fine. Compressor clutch engages properly.
Just had the Freon extracted and refilled to spec by a reputable import shop, but the ac only blows cold when the rpm is over 2k.
Any thoughts?
Old May 10, 2025 | 11:34 PM
raysigh's Avatar
Nothing to do with speed as well. I can be completely stopped, give it revs in neutral, and the moment revs are over 2k I have ac.
Old May 11, 2025 | 02:01 AM
2015LXFIT's Avatar
Failing compressor. Check pressures with clutch engaged; should be 32-40 low side, 150+ high side depending on temps at the time. Probably has enough "blow by" that it's only counteracted at a higher RPM. If pressure checks out would be another issue.
Some VWs had a hi/lo solenoid. Not sure of your specific model.
Old May 11, 2025 | 05:24 AM
raysigh's Avatar
My 2010 is an automatic.
Old May 11, 2025 | 08:27 AM
2015LXFIT's Avatar
Reconsider what we're talking about here...
Old May 11, 2025 | 09:38 AM
Drew21's Avatar
The clutch being referred to is the A/C compressor clutch.
Old May 11, 2025 | 11:24 AM
raysigh's Avatar
Ah. Duh thanks
Old May 11, 2025 | 11:27 AM
raysigh's Avatar
This definitely isn’t a dirty condenser issue right? Dirty condenser would just be low ac performance at all times, but gets better with speed?
Old May 11, 2025 | 01:04 PM
Mister Coffee's Avatar
Any thoughts?
Um, pardon my dumbness, but the condition that you have described sounds normal to me. Our little cars don't throw off a lot of A/C cold air except at highway speeds.
Perhaps I'm missing something. I usually am . . . .
Old May 11, 2025 | 01:43 PM
raysigh's Avatar
I’ve definitely heard of these fit’s ac’s being pretty weak, but my ac is blowing 0 cold air at all below 2k. That’s what yours does?
Old May 11, 2025 | 03:01 PM
Drew21's Avatar
To echo Mister Coffee, my 2010 Fit Sport doesn't make much cold air at lower RPM. I wouldn't say "0 cold air" but it's not a lot.
The vast majority of my driving is on the highway at speed, so this doesn't really bother me. If I'm going slow/low RPM in town I rarely bother with the A/C and put the windows down instead.
Old May 12, 2025 | 10:56 AM
raysigh's Avatar
Well back to the original question then, what could 0 cold air below 2k possibly be? Still possibly a bad compressor? Dirty condenser?
Old May 12, 2025 | 08:51 PM
Alexander Chernoch's Avatar
Do your fans turn on when the AC compressor is running/engaged?
Old Jun 6, 2025 | 01:40 PM
raysigh's Avatar
yes the fans turn on. My condenser fins are pretty gummed up and not in great shape. Could that stop cold air below 2k rpm though?
OrangeFit12
Oct 15, 2024 11:53 AM
werd814
Sep 5, 2022 11:22 PM
Dj365
Sep 2, 2020 05:15 PM
taxonomy
Jun 17, 2017 10:08 PM
MorganKl
Jul 1, 2013 01:49 AM
