Radiator fan not working
Old Sep 20, 2025 | 08:42 PM
clofol1's Avatar
Question Radiator fan not working
Howdy y'all,
I'm trying to fix my radiator fan not working and have gone through a few different steps. The AC condenser fan is working fine and I double checked the voltage coming from the main fan motor fuse (30A). The relays were ruled out by switching the radiator fan and condenser fan ones, the AC condenser fan came on again after the swap.
I'm down I believe to the radiator fan itself not working or the coolant temperature sensor not reading correctly. I checked the engine coolant temp with an OBDII reader and made it up to 212F without the fan coming on. I wanted to do the paperclip trick to check the coolant temp sensor to fan connection, but am not sure where it's located.
Anyone know where the temp sensor is located? I'm assuming if the the OBD engine temp is right, then perhaps it's the fan itself? Any other thoughts would be greatly appreciated - I've gotta drive to work on Monday!
Old Sep 24, 2025 | 01:18 PM
Mister Coffee's Avatar
This?
Senicova
Aug 16, 2024 05:19 PM
gerard6496
Jan 12, 2024 02:12 AM
Gerald Grimaldo Abellon
Jul 30, 2019 11:49 AM
wzard999
Nov 17, 2013 08:58 PM
fit4jdm
Oct 21, 2008 01:39 AM
