2012 GE8 fit CEL flashing loss of power
Old Dec 6, 2025 | 08:21 PM
Oabeieo's Avatar
While driving , CEL comes on but flashes not on solid , car Boggs out , won’t accelerate very much, I pull over , turn off engine …. Wait a min , start car , car sounds like it’s bogging for about 10 sec then everything all of a sudden starts to drive perfectly fine and dandy. No CEL , all normal
Wtf causes that!!! ??
I will scan it tomorrow, I’m away from my shop rn.
any ideas ? 147k , battery is ok , altho car has upgraded audio , I know it needs valve adjustment soon, it’s not clanky but I know it’s due , otherwise perfect maintenance history.
Any ideas much appreciated
thanks in advance
Old Dec 7, 2025 | 09:39 PM
bobski's Avatar
Check/replace your engine ground cables. Try jiggling the (possibly worn) ignition switch?
Old Dec 8, 2025 | 10:26 AM
zcargo's Avatar
Flashing CEL means misfire, I think? Loose spark plug(s), bad spark plug(s), bad coil(s), bad injector(s), valve adjustment, as stated.
Code scan will probably be your friend.
Mark
Old Dec 8, 2025 | 10:31 AM
bobski's Avatar
Huh. Yep:
Old Dec 8, 2025 | 12:20 PM
Oabeieo's Avatar
Mark
Originally Posted by bobski
Huh. Yep:
aaah thank you guys , no stored codes
loose spark plugs aye, snap that happened at 80k , I could smell fuel and ended up changing the plugs. I don’t smell fuel but probably should take a peek anyway….
yeah last thing I need is one to launch and rip threads off , that would really suck.
So , I’m going to clean my battery terminals and clean where the ground goes to the body (which I upgraded to zero gauge, and put new plug in again…
I super appreciate the post with that page. Is that from the owners manual?
Andrew
Old Dec 8, 2025 | 01:23 PM
bobski's Avatar
Yes. Search the web for "Honda Fit <model year> owners manual pdf". It's free to download from Honda, no account needed or other silliness. The PDF has click/tap-able links, like the dashboard diagram on one of the early pages has an "Indicator Lamps" label with a link that takes you to the section with the first page I posted. The blue "If The Malfunction Indicator Lamp Comes On or Blinks" link takes you to the second page I posted. It's digital so it can be searched from your PDF viewer app. Overall its more convenient than the print version IMO.
12' fit
Sep 23, 2021 09:24 PM
elkaku
Nov 24, 2020 10:08 PM
1fit2fit
Jun 24, 2017 10:06 AM
Almost_useless
Jan 2, 2016 11:45 PM
Bry028
Nov 5, 2012 12:35 AM
