did i mess up my valve adjustment?
Old Mar 11, 2026 | 01:00 PM
justafih's Avatar
Recently purchased a 2010 honda fit with 210k miles. It was on original coils, spark plugs, drive belt, and without a valve adjustment. Did all general maintenance without problem until the valve adjustment. After starting the car up and doing an oil change since it was due, I noticed the car sounded a little too clicky. Did I leave the valves too loose?
Old Mar 11, 2026 | 03:51 PM
bobski's Avatar
Sounds like it.
The engine is supposed to be overnight-cold for the adjustment. Valve lash shrinks as the engine warms up, so setting it to the specified value with a warm engine will result in too much lash, causing valve train noise.
Too little lash can result in the valves not closing fully when the engine is hot. That would obviously cause compression leakage (loss of power, emissions problems), but also overheated valves, as the valves shed most of their heat through the valve seat (the ring where they seal against the cylinder head). Overheating causes "burned" valves, where the heat warps and/or erodes metal from the valve such that it no longer seats and seals properly, even when cool and/or lash corrected.
To much lash = noisy valves. Too little lash = cylinder head rebuild with machine shop work. You need less lash, but be careful.
muki
Nov 25, 2025 02:36 PM
SilverEX15
Oct 27, 2025 04:43 PM
strannik
Apr 18, 2024 05:36 AM
mowfixer
Apr 30, 2022 05:14 PM
hollyh
Mar 11, 2016 10:43 PM
