17MM brake caliper replacements (UK)
Old May 31, 2026 | 04:34 PM
LemonEyez's Avatar
Hi, first post here, I have a imported Japan Honda fit GE6 2010 that has the small brake package, I’ve searched all over but I can’t seem to find any replacement non OEM callipers, the OEM would cost about £250 each being imported from Japan…I have Pair of Front Brake Disc Fits Honda Fit OE 45251SAA901 Blue Print ADH243119
which have a brake disc maximum thickness of 17MM, all the callipers I look at have 21MM.
45018-SAA-900 Is the part number.
is anybody able offer any help of this matter, thankyou!
Old May 31, 2026 | 08:57 PM
bobski's Avatar
Have you considered ordering the rebuild parts? Looks like 01463-SAA-900 for the seal set, and 45216-S5A-003 for the piston.
Old Jun 1, 2026 | 10:48 AM
LemonEyez's Avatar
  • Yeah I suppose, never considered it figured it would be a jaunt of a job but just looked at a YouTube video and seems easy enough, thankyou my man, saves me a good few hundred!
Old Jun 1, 2026 | 11:08 AM
bobski's Avatar
Getting the piston back in can be a bear (usually due to rust in the caliper's seal-holding grooves), the rest is pretty straight forward.
If you're thinking about switching to other calipers, check if the donor car's steering knuckle (part the caliper bracket bolts to) has the same part number as yours. If so, that tells you the donor calipers should bolt up. Similarly checking the hub part numbers will tell you if the rotors will fit.
Bubble
Oct 20, 2023 02:01 AM
exl500
Apr 30, 2021 02:22 PM
Mister Coffee
Oct 20, 2019 01:31 PM
logger 1
May 31, 2018 08:46 AM
lilcat
May 5, 2009 01:00 PM
