Rear Door panel removal
Old Sep 19, 2008 | 09:36 PM
TWGE08's Avatar
Does anyone have instructions on how to remove the rear door panel? I have a rattling issue that I wana fix.
UPDATE:
Ok well I took the rear door panels off today and took some pictures for future reference.
First off there are 3 tabs that you wana push in on the door handle and then pull off the bottom part plastic part. This will reveal 1 of the 2 screws that need to be removed.
The 2nd screw is on the door opener.
Then all you need to do is remove the 6 clips at these locations by pulling at the panel.
After the clips are loose, unlpug the window switch and slide the door opener through the panel. Then just lift the panel up and there you go.
Old Sep 19, 2008 | 10:13 PM
CrystalFiveMT's Avatar
I don't know the answer, but I just removed my driver's armrest on the door to solve a minor rattle. I wanted to remove the rest of the door panel so I can have better access, but I was afraid to break clips or something.
But it would be good to know how to remove panels. If someone knows it would be appreciated.
Old Sep 20, 2008 | 12:16 AM
TWGE08's Avatar
What was causing your rattle?
Old Sep 28, 2008 | 12:14 AM
TWGE08's Avatar
Removed the panel today and took some pics.
Old Jan 2, 2009 | 02:34 PM
vwli's Avatar
How about front door panel
Got any pointers on removing front door panel? I am planning to install some new speakers.
Old Jan 2, 2009 | 03:31 PM
TWGE08's Avatar
Sorry no pics for the front. I removed the back panel to fix a rattle that I was having. If I do remove the fronts I will post pics.
Snake
Jan 4, 2015 10:51 AM
wait4thefit
Feb 1, 2012 12:16 AM
phenoyz
Nov 1, 2010 08:51 PM
badself
Sep 22, 2008 11:32 PM
dbagnulo@gmail.com
Aug 26, 2005 05:31 PM
