USB Port to Charge cell phone, etc
Old Feb 18, 2010 | 06:17 PM
dmctom's Avatar
Smile
opps.....replied to the wrong quote!.....Doh! This is an old comment below...Sorry for the mistaken thread grab.
Originally Posted by LimpBagel
The manual says don't use a USB hub.
Old Feb 19, 2010 | 05:34 AM
BobsUrUncle's Avatar
BlackBerries
Works with Blackberry 8310 and 8900 (AT&T). I bought long USB cables, cut a hole the size of the small connector in the upper glove box, and ran it through the dash to pop up next to the passenger seat so I can put my phone in the slots next tot he emerg. brake handle. I don't have any issue with EDGE chatter in the car.
The USB port Charges the phone and I can play the music I have on the device.
Tried a Bold, for some reason could not get music to load.
Old Feb 19, 2010 | 05:53 AM
crash001's Avatar
If u need to charge using sb walmart sells an adapter u plug it into the cig lighter plug and can plug two USB in I use this for my iPhone 3gs since I got a base
Old Feb 19, 2010 | 01:30 PM
dtmbmw325i's Avatar
I have a palm centro and it does not charge via the usb port in the car. It does on a laptop but only if the driver is loaded. I believe it does not charge in the car because the driver is not being loaded to initialize it. A blackberry should be able to play songs over usb because when connected it asks about being connected using mass storage mode. This allows the phone to act like a usb storage device like any thumbdrive or ipod. The key is mass storage mode. I heard that android also does something similar in that case would also work sending saved music on the sd card through the stereo. Hope this helps.
dwjngs@gmail.com
Jun 14, 2017 02:13 PM
Shipoffools
Mar 12, 2017 09:59 AM
acter
Mar 13, 2015 05:37 PM
BakedCookies
Mar 20, 2011 10:34 PM
wacky wick
Jul 8, 2010 09:44 AM
