Receiver Hitch; Suggested Uses?
Old Oct 16, 2008 | 10:04 PM
dzager's Avatar
Monroe MA793 for air shocks 2009. Right length. You have to sleeve the bottom bolt - then it mounts as easy as the 811's for the 2008.
Dave
Old Oct 16, 2008 | 10:40 PM
IfTheFoo's Avatar
Dave
How do adjust them? with a manual hand air pump?
My Road King has air shocks on the read, there's a little hand pump and pressure gauge use to set the suspension.
Old Oct 17, 2008 | 02:21 AM
CBX's Avatar
CBX
I wonder whether a dedicated air shock thread might be warranted.
txmatt pointed out this LED brake light insert Oval L.E.D. Brake Light Trailer Hitch Receiver Cover CR-017 : Trailer hitch bike rack and trailer hitches - etrailer.com which might have some value when the bike rack (or whatver) is not in use.
Old Oct 17, 2008 | 09:12 AM
tcdonaghey's Avatar
Originally Posted by manxman
Awareness and pre-planning has saved me from two car wrecks (totaled), two plane crashes, and two coal mine explosions. Getting what I want out of a car without risk from a dealer is easy.
Er - do tell?
Old Oct 17, 2008 | 10:39 AM
FitStir's Avatar
To paraphrase Murphy's Law- "In any situation, anything that can go wrong will go wrong".
ooooh Murphy's Law.. gotcha.
Yeah it would have been nice to fit a full piece of sheetrock in the Fit, as occasionally I do have to carry construction supplies. Or on other occasions when I need to bring out more equipment for gigs, a small box trailer would be nice. So I definately gotta look into those Monroes
Dave
I don't know if I wanna attempt the replacement of the springs myself, I might just buy them and have my mechanic friend install them. Although reading that DIY, I think I can do it myself, but what does "sleeve the bottom bolt" mean?
Thanks for the verification on the part #, +reps for ya too.
Does this void any warranty as it is not factory shocks?
I think I'm gonna probably use this Large Square LED Brake and Tail Light Trailer Hitch Cover with Reflector Technology on the hitch more than anything else, and pretend I'm driving a F1 car. Now I'm thinking I should have gone with the Auto instead of manual for the ~F1 style paddles.. lolol.. Not!!
I do like the square LED hitch cover a lot though!!!! I just gotta remove it if I park on the street, or it will definately get hit.
Old Oct 17, 2008 | 10:56 AM
EXWRX's Avatar
I like to look of the light a lot. . .
The only downside of that light is that you'll have hooked up "a trailer lighting kit." Since Honda doesn't recommend towing with the Fit, they'll be able to claim you were towing something larger than a bike rack, and try to deny warranty claims.
Old Oct 17, 2008 | 11:01 AM
txmatt's Avatar
The argument could go the other way as well... you thought the light was cool and the only way you could make it work was to hook up the trailer/light wiring kit.
Old Oct 17, 2008 | 06:53 PM
ProMed's Avatar
Originally Posted by BlackUp
heres those capacities:
Max Load Weight (kg) 1555
Maximum roof load (kg) 50
Maximum towing weight with brakes (kg) 1000
Maximum towing weight without brakes (kg) 450
Thanks for posting those up. This is the first I have seen the recommended max tow weight for without using trailer brakes.
992lbs without the brakes
Old Oct 18, 2008 | 02:47 PM
BLACKTHUNDER's Avatar
For those worried about warranty issues for a towing hitch, i remember someone saying if there are no lights hooked up they are more ready to believe it is a bike rack not a trailer hitch...thunder...your opinions may vary
Old Oct 19, 2008 | 07:46 PM
CBX's Avatar
CBX
How about a motorcycle trailer in a bag;
Motorcycle atv scooter trailer In a Bag
cmkallenbach
May 4, 2022 01:19 PM
skijoring
Jan 29, 2012 02:55 PM
YeeFit
Nov 16, 2008 10:47 AM
TOMC&O
May 12, 2008 06:02 PM
eyedryve
Mar 27, 2007 04:01 PM
