judging the distance up front
Old Nov 5, 2008 | 03:05 PM
Neebs's Avatar
Originally Posted by FiveFreshFish
Has anyone got one of these parking poles? They're popular in Japan.
Car Parking Pole Manufacturer exporting direct from Taiwan
Those are hard to come by and they are $250-300.
Old Nov 5, 2008 | 03:50 PM
FiveFreshFish's Avatar
That much? Wow, I've never priced them out before.
The ones I've seen are just a plain old plastic rod but I didn't find a good picture of one. Unfortunately, it appears that most of them require some drilling or cutting of the bumper to mount.
Old Nov 5, 2008 | 07:13 PM
Cat's Avatar
Cat
For my parking space at work I always back into the spot and there is a black plastic dot on the wall. I know how far to back up per where that plastic dot is with the back of the hatch window! Works everytime.
Cat :x
Old Nov 7, 2008 | 01:11 PM
pbanders's Avatar
Tennis ball and a string works fine in my garage, total cost was about $1.
Old Nov 7, 2008 | 06:44 PM
Originally Posted by mugenpower88
i noticed on new cars it's often hard or impossible to see the hood such as the Nissan Versa and on the new Fit.
seeing the fact that it's hard to see the hood (from the front seats), how would you rate your judgment on the distance between the front end of your Fit and the car in front of you? i.e. parallel parking or the car in front of yours in a lane.
did your car ever touch the bumper (even just a small bump) of the car in front of yours when it comes to parallel parking like in a tight spot?
anyone has light scratches on their bumper due to parking?
The tennis ball setup doesn't work for parallel parking.
Old Nov 7, 2008 | 06:55 PM
Surviver of the Fittest's Avatar
have someone stand right in front of the car many times to get yourself familiar w/ the distance between the driver's seat and the object right in front of the car. after some practice you can eyeball it. it's like learning to cook - no seasoned cook uses measuring spoons for ingredients. it's all in the head.
Old Nov 7, 2008 | 07:08 PM
Giggles's Avatar
It took me a little while to get used to not seeing the front end but there is a reason for designing it that way...believe it or not. The front end tapers (which make it invisible to the drive) but does so for pedestrian safety. That way if you smoke the person stepping off the curb in front of you they tumble over the car instead of being sucked under.
Old Nov 7, 2008 | 09:17 PM
polaski's Avatar
I always figured:
If you're sitting in the driver's seat, look at the left mirror's bottom edge. Where you see pavement behind that roughly lines up with the front of the car.
Worked perfect in the EJ, but in the Fit I gotta allow about 3" extra.
Or, alternately, you could drive a rear-steering 4-ton lift vehicle at speeds exceeding 10 mph with sometimes less than an inch clearance on every corner when turning into storage lanes, and really appreciate how doggone easy it is to park a Fit.
Old Nov 7, 2008 | 09:44 PM
Rubba Burna's Avatar
HID Addict
Originally Posted by ERyan1189
ey do you have any night shots of your 7000k headlights?
Erm, not to "encourage" to be off topic but just replying....
Old Nov 11, 2008 | 02:46 AM
mugenpower88's Avatar
interesting...where did u get this info?
Old Nov 11, 2008 | 06:10 AM
Giggle is right. I read the same thing from honda's own material about the front end design that minimize pedestrian injury. I don't remember exactly where I saw the info. I do remember seeing a detailed description of Honda's ACE body structure as well as other safety features, along w/ illustrated drawings. Probably from the Japanese Fit site. I don't know Japanese but a typical Japanese writing contains enough Chinese characters (Kanji) for me to guess the meaning.
Old Nov 11, 2008 | 11:22 AM
  #32
This is the reason for the high hoods on all new Hondas and virtually every new model from other major manufacturers. One of the pedestrian safety requirements is a minimum gap between the engine and the inside of the hood of 10 cm (4 inches). Pedestrian safety through vehicle design - Wikipedia, the free encyclopedia
Personally, I dislike the look of this on regular cars because it makes them tall, appear bulky and reduces downward field of view ahead of the car.
Old Nov 11, 2008 | 11:37 AM
  #33
JDMxGE8's Avatar
I can't see the front, even if I stand up. I usually just stop to where I feel it's safe. Lol!
SilverEX15
Sep 18, 2014 04:30 PM
grtpumpkin
Feb 2, 2009 04:48 PM
BrianT
Jul 9, 2008 07:00 PM
s0x
Dec 18, 2007 08:11 PM
WaitinginVT
May 11, 2006 02:16 PM
