Stereo - Audio stopped working!?
Old Nov 5, 2008 | 12:50 PM
animes2k's Avatar
Ok, so my wife comes in the other day after having reset the clock for daylight savings and says the stereo doesn't put out any audio. And it's true. Regardless of how high you turn the volume up, there's NO audio coming from the speakers, not even static or a hiss.
All of the functions of the stereo appear to be working otherwise. The AUX/USB works fine, shows tracks, navigates the folder structure. The radio finds stations, shows the ST indicator (for "stereo") etc. Just no audio. Tried adjusting the speaker balance and fader with no results.
It's the strangest thing.
I tried pulling the 30A stereo fuse and it's intact. Is there a separate fuse for an amp?
Thoughts?
Old Nov 5, 2008 | 01:53 PM
kingofpicklez's Avatar
you should definitely take that to the dealership to see whats up.
Old Nov 5, 2008 | 05:19 PM
animes2k's Avatar
Looks like that will have to be the solution. I've checked all the fuses that are remotely related to the radio (that I can identify), reset the whole thing by unplugging the battery for 20 minutes (had to enter the radio code) and checked all the connections on the back of the stereo unit to make sure they're secure (as best I could from the glove box). Everything SEEMS to check out.
Off to the dealership.
Old Nov 5, 2008 | 05:54 PM
cranky18's Avatar
wife................reset..... clock.................stereo doesn't put out any audio.
Hmmm.......I see a pattern here
JK My wife doesn't like to touch anything because if something goes wrong she knows the first thing she will hear is "what did you do?"
Old Nov 7, 2008 | 04:20 PM
animes2k's Avatar
I dropped it at the dealer today and the conclusion is...
Problem is in the head unit. Replacement has been ordered. Should be about a week.
Old Nov 22, 2008 | 12:08 AM
animes2k's Avatar
Just an update - got the new head unit installed today. New radio code card and all. Looks like they managed to get it right - it all works
Old Nov 22, 2008 | 09:40 AM
SomberResplendence's Avatar
Sweet, I'm glad your problem was taken care of. Now go pump up that music!
Old Nov 22, 2008 | 01:04 PM
animes2k's Avatar
Definitely will do! I'm going to dynamat the front doors (friend has lots of extra) and then consider replacing the front speakers...
Old Nov 22, 2008 | 01:16 PM
trancedsailor's Avatar
that problem sucked man I've never heard of anything like that for Fits yet. You're the first haha hopefully there won't be more?
Old Nov 23, 2008 | 10:22 AM
mardar7's Avatar
I'm having a similar problem. I had a sirius radio installed (hard wired) and now, about once a day, the Sirius doesn't power up when I start the car and there is no audio from the radio or CD player, even though its running. If I start the car again, everything will work. Need to take it back to Best Buy who did the install.
fbones24
Oct 14, 2014 09:03 PM
chadew
May 13, 2011 04:22 PM
CraigK
Nov 7, 2009 08:40 PM
Praze
Jun 26, 2008 06:11 PM
SaraKat
Aug 22, 2005 11:30 AM
