GE8 Post your Problem Rattles and shakes !
Old Nov 17, 2008 | 05:19 PM
Jammy's Avatar
I had a rattle develop after 500 miles at the dashboard seam underneath the steering wheel. Took it to the dealer and had them fix it while they were replacing a DOA TPMS sensor.
They said the metal clips holding it together just needed adjusting, but it took them a while to figure it out because they'd never seen one before
Old Nov 18, 2008 | 12:18 AM
ccaddy's Avatar
My lower glove box started rattling on it's first two hour highway trip .
This was at roughly 500 klm's .
No worries , I'll have them look after it at the first service .
Old Nov 18, 2008 | 09:34 AM
nausicca's Avatar
My left side dash (somewhere near the instrument cluster or below the left side vent) rattles when it's cold, but goes away after driving for 10 or 15 minutes. Can't figure out what's causing it.
Old Jan 4, 2009 | 08:53 PM
Chainsaw's Avatar
I have a lower glove box rattler. I was wondering what techniques have been used to cure this. Leaving the glove box open is an unacceptable cure.
Old Jan 4, 2009 | 09:47 PM
Blackout's Avatar
09 AT W/NAV so far so smooth... and just so eveyone knows if you do hear a sound that's not normal take it in its ok to do that
Old Jan 4, 2009 | 09:57 PM
method:fitsport-K's Avatar
Lower plastic fuse cover rattles. Taking it to the dealership tomorrow.
Old Jan 4, 2009 | 10:19 PM
No_Skillz's Avatar
Something near the driver's side B pillar. By my (drivers) left ear. Tiny, barely noticeable.
Old Jan 4, 2009 | 10:25 PM
KatzeChicX's Avatar
I hear two rattles and at first they drove me insane. Then, I realized they were just my stupidity.
First, water bottles rattle when they are in the door holders.
Second, just the slightest swing to my keys causes them to hit the steering column and make a rhymic noise.
Other than that, I've found surprises in my cargo area thanks to my husbands nack of leaving stuff in there.
My favorite (this is from my last few cars too) is when you leave a water bottle in the car (half drunk) on a cold day and then turn on the heater. In my old car, I thought I kept getting hit by rocks. To be fair, I did get hit by rocks a lot in my Integra. But, about half of the worry was spare water bottles tucked here and there.
Old Jan 5, 2009 | 03:42 AM
kimonostereo's Avatar
No rattles yet. Only a little over 500 miles on it so far though....
Old Jan 5, 2009 | 01:18 PM
tenklavir's Avatar
I don't have any rattles, but every time I come to a stop at a light or a stop sign, I hear what sounds like liquid sloshing around somewhere in the car. It's not always in the same place either; sometimes I hear it in the back and sometimes I hear it in the front. Anyone else have that?
Old Jan 5, 2009 | 01:21 PM
cranky18's Avatar
Gas tank under passenger seat.
Old Jan 5, 2009 | 01:24 PM
  #32
tenklavir's Avatar
Interesting. Never heard it in any other car but then again I never really tried paying attention to every little noise it makes. As long as I'm not the only one that hears it
Old Jan 5, 2009 | 01:25 PM
  #33
cranky18's Avatar
I usually only hear it when I am pulling into the garage. Keep your gas tank topped off at all times and I bet you won't notice it.
Old Jan 5, 2009 | 01:27 PM
  #34
achia's Avatar
yes sir, my lower glove comp. does rattle
Old Jan 5, 2009 | 02:31 PM
  #35
flyjake's Avatar
I also had a lower glovebox rattle in my new (730 mile) Fit. I solved it by putting in a thin layer of foam in the bottom. It seems that anything sitting in that box will rattle against the plastic, and the sound becomes greatly magnified.
Old Jan 5, 2009 | 02:44 PM
  #36
CrystalFiveMT's Avatar
My passenger vent cup holder is the cause of my remaining annoying buzz/rattle. I've been working on it for a month or more, but it's not completely gone. If I can figure out how to remove that cup holder or the surrounding dash that would be great. But since I don't know, I'm planning to give it to the dealer and have them take a shot at it.
Old Jan 5, 2009 | 03:53 PM
  #37
projekz's Avatar
My lower glove box rattles but only on really cold days...My gas tank sounds like the ocean when it's under a 1/4 tank...Kind of relaxing actually
Old Jan 5, 2009 | 03:59 PM
  #38
achia's Avatar
Like the ocean? Honda Yacht
Old Jan 5, 2009 | 04:11 PM
  #39
Red Rider's Avatar
Handle (Bar) used to adjust front seats forward and backward. They rattle (buzz) on seat track when seat is positioned to the rear. Saw paint wear from vibration yesterday. Wrapped small amount of foam rubber and tape to bar. Problem solved. I assumed noise was near glove boxes till I found paint wear.
Old Jan 5, 2009 | 04:44 PM
  #40
BakedCookies's Avatar
still rattle free after my short shifter install with solid shift assembly mounts, and ambient light kit install.
