Radiator cooling fan running a lot
Old Jan 28, 2009 | 03:08 PM
RUFit's Avatar
I have noticed that the cooling fan for the radiator has been running a lot. This morning when I started the car, after sitting all night, the fan kicked on right away even though the light for the coolant was still on saying it was cold. Anyone else have this problem? It is 65 degrees out and the car has 475 miles on it. Any help would be appreciated.
Old Jan 28, 2009 | 04:04 PM
luv4jdm's Avatar
I get that too when I start up the car and sit and idle for alil bit.. It doesn't happen frequently but I think its normal.
Old Jan 28, 2009 | 04:06 PM
projekz's Avatar
Is your A/C on or are you in defrost mode? That's probably it.
Old Jan 28, 2009 | 04:39 PM
Virtual's Avatar
Exactly. Many people don't know that the AC is automatically on when the air selector is on heat/defrost or defrost. There's no indicator light, just the fan noise tells you.
Old Jan 28, 2009 | 08:06 PM
TaffetaWhite's Avatar
Someone that spends her life on FitFreak.net
Also, when running defrost, the air vent should be set on FRESH air, not recirculated!!! ALWAYS.
Old Jan 29, 2009 | 12:51 AM
Goodguy-Fly's Avatar
+1. It turned on when it was negative 25 earlier this year. The FitFreak community has figured out a way to disable it--IIRC, I can't remember the thread title though.
Old Jan 29, 2009 | 01:13 AM
niko3257's Avatar
FitFreak GE8 DIY Guy
there is more info here on this.
very easy fix.
https://www.fitfreak.net/forums/2nd-...c-defrost.html
Old Jan 29, 2009 | 03:14 PM
RUFit's Avatar
Thanks everyone for the information and links. Now that I think about it the selector was set to non recirculating defrost so it must have been a fan for the AC and not for the temperature of radiator coolant.
gerard6496
Jan 12, 2024 02:12 AM
hogwylde
Sep 29, 2011 02:44 PM
fit4jdm
Oct 21, 2008 01:39 AM
Edward Man
Oct 16, 2006 10:53 PM
Mugen_Dom
May 13, 2006 10:18 PM
