sub on stock navi ?
Old Feb 21, 2009 | 02:04 PM
vulcaninja's Avatar
sub on stock navi ?
Was wondering if the sport nav/head unit has any output hardware for a sub on it.
This thing does not sound that great but I could deal with it a little easer if I could get a small sub to work. Anyone see the back of this head unit yet ?
Old Feb 21, 2009 | 02:11 PM
niko3257's Avatar
FitFreak GE8 DIY Guy
sorry nothing there for ya.
but if you get line level converter you will
have rca jacks.
Old Feb 21, 2009 | 02:23 PM
vulcaninja's Avatar
Kinda thought they would be on the cheap when the oem unit was speced.
So I guess the line level outs would have to be off the rear speakers?
Old Feb 21, 2009 | 06:57 PM
niko3257's Avatar
you can do it off the rear speakers.
just make sure you do it from the back of the radio.
it's alot easyer this way.
i put my line level behind the glove box.
Old Feb 22, 2009 | 09:28 AM
vulcaninja's Avatar
which wires or plug on head unit ?
I'll go get the line level converter,sub and small amp for the back. I'm looking to make it real easy to remove when the cargo space is a priority so I imagine some sort of plug for power and inputs would do the job.
Is the plug or wire for the rear spks easy to figure out once I pull the head unit out?
Old Feb 22, 2009 | 11:35 AM
niko3257's Avatar
get your self some wire taps and look on this thread
https://www.fitfreak.net/forums/2nd-...k-install.html
for the color codes for the rear wires.
thats all
Old Feb 22, 2009 | 11:51 AM
Speedee 09 Fit's Avatar
There is also a plug taped to the harness behind the radio with a shorting plug in it, I think it is for the base radio. That's where I got my signal (Turned out to be the front speaker wires, but I was going without a wiring diagram).
Old Feb 22, 2009 | 12:31 PM
vulcaninja's Avatar
Speaker wire or coax ?
Ok almost ready to go shopping for materials but came up with another question. Should I use regular speaker wire or shielded coax from the head unit to the sub ?
d44boy
2nd Generation GE8 Specific Fit I.C.E. Sub-Forum
Apr 25, 2015 06:51 AM
whoa42
Sep 4, 2009 09:56 PM
FitPilot
Aug 11, 2009 11:11 PM
micknkeef
Apr 17, 2009 02:30 AM
nutz
May 25, 2008 11:36 AM
