Just another dang tarted up GE8, couple unique things maybe
Old Jun 7, 2009 | 11:58 PM
Tork's Avatar
Originally Posted by NavyAC
Is it just me or does it look lowered? Maybe it's the black rims. I really like your fit! I was wondering what black rims would look like on my storm silver fit.
It is lowered, RS*R Ti 2000 Down Springs, prolly about 1-1/4 front and back.
Newer Item, bought a PRM Intake a couple weeks ago, installed it on a business trip (parking lot of a Ramada in western MN on my way to SD LOL)
Asked specifically for the original LONGER design (didnt want the short ram, necessatated for the auto trans)
Beautifully made, I really like it a lot!
Old Jun 8, 2009 | 01:32 AM
Tork's Avatar
also tonight I installed the skunk 2 short shifter, (ebay $49 incl shipping)
awesome, best bang for the buck, logically just as good as any other short shifter.
Old Jun 8, 2009 | 01:48 AM
Tork's Avatar
Also did a front little wiper and rear wiper delete.
I use Aquapel (Rain-X on steroids) and rarely use my wipers anyway as the rain beads up and flies off the windshield. And that little wiper does not do all that much.
A side benefit is I was able to adjust the main wiper to a lower position and the view out the windshield is now dramatically uncluttered as is the look of the car from outside.
I think vision in rain will be fine (because of the aquapel) if not I will try a 30" wiper instead of the 28" way before I install the little wiper because I like the cleaner look of the car inside and out so much better (and the likely but small MPG gain)
Old Jun 8, 2009 | 12:00 PM
qbmurderer13's Avatar
Did the skunk2 shifter come with the assembly AND the shifter? Or is it just adapters like the GD?
Old Jun 8, 2009 | 06:23 PM
Tork's Avatar
comes with spacers, paw extension, set screws, and longer bolts and washers (parts go on the existing shifter, basically the bronze ish plated steel parts in the pic)
In studying the Mugen shifter, that looks like it is based on honda parts, (same pivot ball, same shift rod but longer paw, same housing except maybe taller)...so I cant see how the Mugen could be better.....
And yes same kit as I put on my GD, which worked perfectly for 20K miles until I sold it. With red loctite, that extension paw will never come loose (unless you heat it up to about 250 degrees to unset the loctite) Really simple install as you dont really have to undo any cables (except for the paw nylon pivot which you have to do on all shifters I believe)
Old May 4, 2010 | 11:34 PM
blackndecker's Avatar
Looking good man...had to stop by and check out the full thread.
I also nixed the "retard wiper" as my fiancee' likes to call it...LOL.
Love the SSR Type Cs. When you die and go to baller heaven, could you tell 'em that I at least tried?
Old May 5, 2010 | 12:18 AM
thefit09's Avatar
lol, niceeee
Old May 5, 2010 | 06:57 AM
mike2100's Avatar
You guys and your clean SSM Fits are making me jealous :P
Those Type Cs make the Enkeis I was planning on getting look Junior Varsity.
Old Aug 25, 2015 | 12:39 PM
karebu's Avatar
i know this is an old thread, but how did you adjust your main wiper to a lower position?
boyetssilverfit
Oct 11, 2014 11:18 PM
ThEvil0nE
May 5, 2014 10:35 AM
13fit
Jan 7, 2013 03:52 PM
sy11580
39
Jul 2, 2009 04:00 PM
713_fit
Jan 10, 2009 08:16 PM
