Oil Change - Cheapest place to get oil
Hey All,
Is there a cheap place to get Mobil 1 5W-20 Full synthetic? Cheapest I can get it for is $6.29 a quart.
Just wanted to confirm 2009 fit takes this oil weight and it's still 3.8 quarts right?
i usually do the 5qt jug at walmart but if you check sometimes your local autoparts stores have sales going on and they will be pretty much about the same price for the 1qt M1's vs walmart 5qt.
in that case, you wont have to 'waste' that 1qt of oil that remains
inside the 5qt jug. since i have 4 cars i dont have that problem,
but for some folks not sure if you'd be against having left over
oil. guess you can use it to add later on if your engine eats oil.
mav238
Sep 18, 2010 07:29 PM
