Fed up with USB connection issues
Old Apr 28, 2009 | 06:28 PM
Hondafrk's Avatar
Angry Fed up with USB connection issues
I'm getting really irritated with my connection problems, it seems like almost any time I hit a sizeable bump in my Fit, or when i'm driving hard and jolt the car from a gear change, my iPod disconnects from the head unit, it doesn't physically disconnect, but it loses its connection to where the car stops playing music.
Then sometimes when I connect it back up, it will say "unreadable" or something of the sort....
Also, sometimes when I connect it back, it will be fine for a while, then i'll hit another sizeable bump, or shift hard again, and it does the same all over again.
I'm wondering if anyone else's issues are as bad as mine.....wondering if maybe a new usb cord for my iPod might help my troubles, but they are rather expensive so I wanted to see if anyone else is having these problems and if you've consulted Honda about it....i'm hesitant to because I know they'll take the car on a drive and it won't have the connection problems that it has when I drive....just the bitch of it.
I did a quick search but didn't find anything about my problems, my apologies if there's a thread on the subject already - link me if there is...
Thanks!
Jeremey
Old Apr 28, 2009 | 06:50 PM
Scaldy's Avatar
I've seen a thread where a few people had this issue. The solution was to take it back to the dealer to replace the deck or the USB cable. I can't remember which one, but it was covered under warranty.
Old Apr 28, 2009 | 07:07 PM
caliban10010's Avatar
Some things to consider:
If you're ipod uses a small hdd instead of flash memory, the bumps will cause the ipod hdd to have read errors.
The connections for the Ipod and USB connector may be loose. This happens with my old cell phone.
Try putting some music on a USB Flash drive and see if it still has that problem. If it does, then it may be a loose connection with the head unit or wiring issues.
I have my music on a 16GB USB Flash drive, hasn't skipped once. I go over railroad tracks Mon-Fri.
Old Apr 28, 2009 | 07:08 PM
lilaznphatboy's Avatar
ask a friend if you can borrow their usb cable.
maybe its your cable or your ipod
Old Apr 28, 2009 | 07:10 PM
Hondafrk's Avatar
I have the 30G iPod FYI, not sure what Gen it is, not too old really. I'll try the flash drive, just have to find mine, haha.
Thanks for the input fellas!
Old Apr 28, 2009 | 07:18 PM
A quick Google search indicates the storage memory is a small toshiba hdd and it's not recommended for use while running or jogging.
Good luck with finding a solution.
Old Apr 28, 2009 | 07:22 PM
Hondafrk's Avatar
Alright, good info! Thanks a lot, i'm gonna try a sponge or something soft and lay it in the compartment where I keep the iPod and see if it laying on something soft may help my issues.
Old Apr 28, 2009 | 09:08 PM
mole177's Avatar
another vote for usb stick or solid state hd.
Old Apr 28, 2009 | 09:10 PM
1FiTpINOY's Avatar
^^ +1 (10char)
Old Apr 28, 2009 | 09:12 PM
Tork's Avatar
perfect example of great trouble shooting skills, rep for you
I love my 32 G flash drive, good way to go and tiny!
Old Apr 28, 2009 | 09:44 PM
hivemind's Avatar
Another here on the flash bandwagon. Picked up a 16 GB one from NewEgg specifically to live in the glove box.
Old Apr 29, 2009 | 11:35 AM
Blackout's Avatar
i got a new ipod when i get my fit so far nothing like this is happen could it be a bad Ipod???
Old Apr 29, 2009 | 12:31 PM
superfriend's Avatar
I have an 80GB model with a HDD of course and have never had it skip or lose connection.
I would say first, swap out your USB cable (borrow someone's) and floor it over some speedbumps . If it persists, take it to the dealer and have them replace the integrated cable.
Also, like most have mentioned, go with a flash drive. For me, I rely too heavily on my iPod, sync it constantly as I add music or playlists, so I want it updated in my car everyday (also Genius playlists RULE). If you don't care about that stuff, go with a flash drive.
Lastly, if all is not resolved, your iPod is probably jacked. If you can, have Apple replace it, or just buy a new one.
Old Apr 29, 2009 | 02:18 PM
Paul S In TX's Avatar
Same here--I am running an 80 GB Ipod Classic with no issues whatsoever. I don't think the OP's issue is related to the Ipod unless the Ipod itself is failing for some reason, and I doubt that unless there are issues when at rest.
FWIW, my Ipod is plugged into the Apple USB cord that came with it, and is sitting loose, in the upper glove box with no padding, nothing special. In fact, in several years of running Ipods connected to one car or another, I cannot recall dropouts or skipping ever being an issue. I do remember (back in the days when I still used CD's in the car) having the in-dash CD occasionally skip over a hard bump. Not the Ipod though.
I would be looking for a connection issue--either the head unit in the fit, the cable running out of it to the glove box, or the Ipod USB cable. Except for the Ipod USB cable, it should be a warranty item.
I also agree with you on the convenience factor of an Ipod over a flash drive. Flash drives are cheaper--that's the only advantage, as far as I'm concerned.
Old Apr 29, 2009 | 03:01 PM
secondspassed's Avatar
I'm running a 40gb "Third Generation" iPod that's been kicking hard for 6 years on a HDD and it never skips through my '08 Fit's aux jack. Me thinks the HDD is a straw man. There's something wrong with the connection or that cable.
Old Apr 29, 2009 | 08:26 PM
Hondafrk's Avatar
I hear all you guys, I don't think its an actual problem with the iPod because I forgot to mention that i've used the same iPod in my '91 Civic for over a year with no connection problems ever, and the Civic rides quite a bit more harsh than the Fit does, but I also had a brand new Alpine deck with the built in iPod cable, it was a beefier connector but the same connector nontheless.
So yeah i'm thinking it may be in the cable, i'm gonna look online to see how much a new apple cable is and try that first I think.
Thanks for all the helpful advice!
Old Apr 29, 2009 | 11:39 PM
triton.'s Avatar
I connect to a ipod touch. I've noticed that if I connect the ipod touch after the car is started sometimes the fit can't connect. Will take repeated attempts for it to work. Anyone else have this issue? Seems to work better if I connect first then start the car.
Old Apr 30, 2009 | 08:04 AM
ren hoek's Avatar
I definitely recommend this retractable iPod cable I bought, and have been using with complete success with my iPhone (0G v2.2 (5G77)).
The Source By Circuit City : iPod Cables - SCOSCHE IPOD RETRACTABLE USB CABLE
The retractable feature makes connecting/disconnecting/answering phone much easier and keeps the upper glove box neat and tidy.
I bought mine at The Source (on sale) and for $5 extra got a 3 year "no questions" warranty. If it fails for any reason (as these little gadgets can and do), free replacement. No matter how many times it fails. Great product, great warranty, highly recommended.
Old Apr 30, 2009 | 07:37 PM
Alpha Zero's Avatar
^ holy crap!
i bought something similar to that from ebay for under $10 shipped. Havent had a problem at all. Had it for about 5 months now.
Old Apr 30, 2009 | 08:30 PM
05trdxa's Avatar
I suggest a USB flash drive for storing/listening to music in the car as well. I have one that I use specifically for that and it works great. Alot better than my iPod did and I can leave it in the car all the time and not worry about someone breaking in and stealing my $200 iPod. All they will get is my $25 flash drive.
