2009 l15a Differences
Old Apr 30, 2009 | 11:20 AM
atom's Avatar
Where does the extra horsepower come from in the new l15a? This is important for us modders to find out and may be why companies like KraftWerks dont wan't to touch this car.
Increased compression?
Redesigned heads with bigger valves?
Redesigned Intake and Exhaust?
Less power diverted to accessories?
We have ivtec, what did the old one have?
Is the ECU still compatible with piggybacks?
Old Apr 30, 2009 | 12:04 PM
thaffejee's Avatar
They have simply allowed the engine to rev higher, hence more power. Higher redline @ 6800, peak power 88kw now at 6600. Compared to 81kw at 5800rpm on the old l15a, someone please correct me if i am wrong with the figures.
Old Apr 30, 2009 | 12:57 PM
Tork's Avatar
Thats part of it, the rest of the max power comes from the full i-Vtec and better breathing.
Bigger difference is the increased low end torque, resonator intake and cast in head exhaust manifold which may also be why Kraftworks is shying away.
Probably the best info you will find is in this link
2009 Honda Fit - Powertrain - Honda - Press Releases - Selected Story
Old Apr 30, 2009 | 02:26 PM
atom's Avatar
Until today I didn't know the manifold was cast in like that. That's crazy I've never heard of that although I can see the manufacturing/reliability advantage. Well that pretty much rules out turbos; placing one at the end of the stock manifold would probably take forever to spool.
Old Apr 30, 2009 | 04:34 PM
luv4jdm's Avatar
Yea I heard that honda built the GE's to be pretty much unmoddable for the engine part. Unless of course you rebuild the L15 motor wit new pistons and such to make it faster. I think I saw a post by someone who did this and had like i think 300hp. Or stuff a k20...
Old Apr 30, 2009 | 04:59 PM
dela's Avatar
https://www.fitfreak.net/forums/fit-...turbo-kit.html
theres no real info on #s... but its nice to see theres a company trying to step up to the challenge
Old Apr 30, 2009 | 05:29 PM
quick92ciFit's Avatar
Not to hijack the thread, but I thought Kraftworks (sp?) is trying to design a supercharger kit for the GE8 because of the cast in head manifold?
Old Apr 30, 2009 | 05:50 PM
Tork's Avatar
I am not saying it cant be done. Just if it is true (that Kraftworks wont do it? and if the OP is in the 'know'?) thinking of possible reasons why.
The cast in manifold would not kill a supercharger at all. Turbo? Well you probably couldnt hang the weight of a turbo on it and the heat could be an issue. So you would have to keep that in mind with the design.
My wifes Civic has the cast in head header also.
If a kit is available for the non Si Civic then no reason a turbo would not work except more room with the civic as the cast in head exhaust manifold is on the front.
Old Apr 30, 2009 | 08:29 PM
atom's Avatar
GE new ECU is giving tuners the most headache. My cousin is the chief mechanic for Team Honda here in Indonesia and he is so far could not figure out why the car is VERY RICH on top end. GDs does not have this problem, he said and I have checked Hondata's forum to see if they are repsonding to GE owners only to find it has a policy of not talking about anything they are working on their own forum.
GE's L15A needs a reflash before any tuners can discover any horsepower. Greddy piggyback didn't help either.
Source: https://www.fitfreak.net/forums/2nd-...tml#post586772
If anyone finds out any such information poking around please post it here for reference.
Old Apr 30, 2009 | 11:04 PM
cab0053's Avatar
I do recall jdmchris.com saying that the jacksons said the the ge8 would be great/better than the gd3 to supercharge, but had no definite plans.
Old May 1, 2009 | 01:13 AM
rhecht's Avatar
So far from what I have ready, it seems that the ECU is the main stumbling block.
Not sure if any companies are working on solutions yet, if they are they're doing it quietly.
kelly
Nov 17, 2008 08:46 PM
triton.
Oct 1, 2008 10:45 AM
piperpiperpiper
Apr 21, 2008 11:56 AM
gotfitted
Oct 31, 2007 01:25 AM
CarGuy37
Jan 29, 2006 11:39 AM
