Open windows or A/C for best mpg?
Old Sep 14, 2009 | 05:16 PM
seonadancing's Avatar
Here in our country where it's usually around 35C, I keep it a point to put the windows down when i'm the only one in the car. Since i have window visors on, I open my window only slightly lower than the bottom of the visor so i can have some air and at the same time, more engine power.
Old Sep 14, 2009 | 05:22 PM
hex's Avatar
hex
I watched an episode of Mythbusters once and they did a test on this. Having your windows down produces drag. However, they did most of their testing on highway speeds, so if you're driving on the main roads, I would probably just roll the windows down.
Old Sep 14, 2009 | 08:46 PM
Super Mario's Avatar
Around the city I cruise windows down. On the freeway it's usually cracked so that the windows are still under my visors, or A/C, depending on whether or not I'm going uphill.
Old Dec 8, 2009 | 02:09 AM
Vash's Avatar
Mythbusters' mistakes in AC vs windows down episode — Autoblog Green
Old Feb 27, 2010 | 09:42 AM
Bowkr's Avatar
Originally Posted by thepatweir
I know its fun to drive with the windows down but i would not recommend it for your ears sake. Driving witht he windows down is more damaging for your ears than being at a loud concert, you will not notice it right away because it attacks your lower frequencies but the extra 2$ pr fill that you spend on AC will save your hearing when your 70.
FYI, no one should be listening to this guy. If you adjust music higher when windows are open, *that* may cause damage.
High frequency noises can damage your hearing. Not low frequency.
Old Feb 27, 2010 | 10:35 AM
Selden's Avatar
Wind noise is full spectrum. After 48 years of riding mostly quiet motorcycles, I have significant hearing loss and tinnitus 24x7, mostly from wind noise. Unfortunately, I didn't discover foam ear plugs until 1995.
Old Feb 27, 2010 | 10:40 AM
spreadhead's Avatar
This is incorrect. All frequencies can cause hearing loss.
Old Feb 27, 2010 | 11:19 AM
Texas Coyote's Avatar
The V.A. audiologist that fitted me with hearing aids categorizes high frequency loss as classic combat hearing loss and low frequency as occupational hearing loss.... I have both in my left ear, a lesser amount of low frequency loss in my right ear and tinnitus.... After testing me he said he could tell I had been exposed to a great deal of combat and had spent a lot of time driving with my window down.
Old Feb 28, 2010 | 08:26 PM
Koi's Avatar
Koi
Since this question is regarding MPG, the answer is open windows. From my experience the A/C on the lowest setting will cause the engine to lose a great deal of power - as soon as it's on the car will feel like there's 2-3 people sitting in the car going uphill. Since the little engine gets significantly bogged down, it'll take more throttle to drive around, meaning more gas used. Definitely only use it if you have to.
Old Mar 7, 2010 | 07:28 PM
Jensen Healy's Avatar
I've heard a million times how driving with your window or windows open creates so much drag, you're better off using your A/C. I try to keep windows up, and cool the car off with the A/C then turn off the A/C, recirculate the cold air and turn the A/C back on when needed again. Although over 90% of the A/C season I'm getting from here to there on a motorbike, bicycle, public transportation or my feet.
Old Mar 7, 2010 | 07:46 PM
Once you are up to 70 the windows being down will create some major drag.... If you have dark tint and The Mugen type vent visors they will help keep you cool with the windows slightly lowered and the A/C off when the temperature isn't much over 80 degrees and not create as much drag.
Krimson_Cardnal
Oct 25, 2013 05:43 PM
over40pirate
May 14, 2013 08:49 PM
Biven5
May 9, 2008 04:42 PM
necro2600
25
Jan 27, 2008 03:04 AM
polyphonics
Jul 20, 2007 04:15 PM
