anyone with this feeling?
Old Jul 19, 2009 | 05:09 AM
Fitcious's Avatar
this happened twice today...but im pretty sure its nothing.
i am at a red light. i put it in first gear and i get going. I shift at 3k, then when i went to the second gear, it felt as if the shifter was READY to "pop" out of first as soon as possible. like...it feels that it just pops out of first as if it wasn't totally in first yet. it shifted fine and no slip or anything...i just felt weird. hard to explain.
anyone had this happen? is it normal? and yes, i depress the clutch all the way in before i changed gears
Old Jul 19, 2009 | 10:01 AM
Contrabida Face's Avatar
yes!!! it happens to me too! i have a GD3 though. it feels like the car shifted to 2nd all by itself.
Old Jul 19, 2009 | 12:03 PM
vinn's Avatar
yes it happens to me as well
Old Jul 19, 2009 | 12:29 PM
Virtual's Avatar
That happens if you gently pull the shifter as you press the clutch. It won't do it if you press the clutch fully before shifting.
Old Jul 19, 2009 | 12:52 PM
qbmurderer13's Avatar
Its happened to me before. Don't think its a problem just a matter of technique.
Old Jul 19, 2009 | 01:00 PM
it usually happens early in the morning when i'm half asleep.
Old Jul 19, 2009 | 02:09 PM
doctorz's Avatar
happens to me. Anyone know if it's a problem? I usually circumvent the issue by taking the 1-2 shift slowly.
Old Jul 19, 2009 | 02:33 PM
dela's Avatar
it happens when your timings off... press the clutch in too late and start shifting too early... its the shifter popping out of the gate
u can actually shift up without using the clutch... wouldnt recommend it tho... the popping out isnt the problem... its putting it into gear without a clutch can potentially grind up your gears
Old Jul 19, 2009 | 05:02 PM
it's pronounced iVTEC's Avatar
it grinds the Synchro's not the gears one of the many reasons why cars don't use straight cut gears anymore. synchro's are cheaper to replace than a gear
Old Jul 19, 2009 | 05:12 PM
dela's Avatar
ah.. i stand corrected... and now we know...
AND KNOWLEDGE IS POWER!
Old Jul 19, 2009 | 05:13 PM
And knowing is half the battle!
Old Jul 19, 2009 | 05:17 PM
dela's Avatar
lol ok im done... haha
Old Jul 19, 2009 | 09:23 PM
Wopasaurus's Avatar
Old Jul 19, 2009 | 09:42 PM
You sir.. read my mind.
tigawoods
Apr 10, 2019 11:36 AM
cgpEJ6
Aug 31, 2017 11:50 AM
robs
Sep 27, 2015 12:57 PM
chunkylover8200
May 2, 2012 04:28 PM
bigcanoe
Jan 15, 2010 11:36 AM
