map light for base model
Old Aug 11, 2009 | 02:30 PM
bensenvill's Avatar
I didn't think it would bug me not having it, but ya, I have to address that.
has anyone added the sport's map light to the base model?
Anyone know if its just cutting the headliner and adding the light or if the wiring harness needs to be added up the A-pillar as well.
Old Aug 11, 2009 | 02:35 PM
secondspassed's Avatar
you can tap the power from the dome light, cut a hole and stick it in. It should stay since every time you push it you're pushing it in. Mine hasn't budged.
Old Aug 11, 2009 | 03:11 PM
yah, ALL of us with GD's had that problem. luckily for me, i found a diy from wdb and i just copied his idea and wired up a maplight from a STI. hahahaha.
considering that the GE sports have maplights, should be a very
easy cut and mount for you.
Old Aug 11, 2009 | 03:17 PM
https://www.fitfreak.net/forums/fit-...k-install.html
I did a DIY for this about a year ago but I can't find it. I found somebody elses. Hope it helps.
waxyourboard
28
Apr 14, 2019 11:15 PM
Jephu
Jun 8, 2015 12:18 AM
TwoFits
Feb 2, 2013 08:13 AM
Swangger
Nov 21, 2012 02:44 AM
aznbigman
Jul 13, 2009 05:35 AM
