Bubbling noises from the engine?
Old May 3, 2014 | 05:06 PM
Steve244's Avatar
air in the cooling system. no big deal. It'll work its way out the overflow tank eventually. Just make sure the overflow tank has coolant between the min max. Watch it because it will suck in fluid to replace the air that is purged.
I'm assuming it got low and sucked air in or you wouldn't be having this happen.
there may be a purge valve somewhere on the engine to get rid of air more quickly, but I don't have a GD manual to check.
Wreck Ignition
Mar 14, 2024 03:24 PM
willfit07
Nov 21, 2016 05:25 AM
Bugzs15
Nov 5, 2013 06:57 PM
john21031
Oct 19, 2009 10:45 PM
theo.chan@gmail.com
Oct 19, 2005 02:39 PM
