no lights on AC knobs since radio replacement
Old Oct 9, 2009 | 08:06 AM
polokid69's Avatar
any one have any ideas why when the lights are on, the ac knobs are no longer illuminating ? could I have unplugged something by accident ?
Old Oct 9, 2009 | 10:02 AM
billmus86's Avatar
My Lips Bigger!
does your fan speed still work?
theres two plugs on the bottom one for the fan the other for lights and acswitch..
check em both..
Old Oct 9, 2009 | 10:52 AM
polokid69's Avatar
check em both..
fan speed works because I had air on the way to work. I'll pull the head unit this afternoon and see I knocked a wire loose.
Old Oct 9, 2009 | 10:57 AM
polokid69's Avatar
it's possible I moved or bumped something reinstalling the HU yesterday
Old Oct 9, 2009 | 02:47 PM
billmus86's Avatar
My Lips Bigger!
theres two harnesses at the bottom-
the lights are sep from the fan speed -- but plug in right next to it.
all you have to do remove is the bottom trim piece to see them
its a smaller gray plug.
Old Oct 9, 2009 | 09:35 PM
polokid69's Avatar
I didn't see anything disconnected when I had the HU out again for another reason. I have the lower cover off, and did not see what you were talking about.Would it have any affect me having the 12volt plug disconnected ?
Old Oct 10, 2009 | 12:29 AM
billmus86's Avatar
My Lips Bigger!
no, if you have only one plug - plugged in... thats your prob.
if theres two then you are good at that point of failure.
Old Oct 10, 2009 | 11:28 AM
cbs1013's Avatar
I had the same problem when I installed my head unit. I got sloppy and forgot to cover the end of one of the wires i wasn't using, which was touching a piece of metal behind the dash, which caused a fuse to blow. Can't remember which fuse it was but I know it was a 10 amp (maybe labeled Acc Light?) So check ur fuses, then check and see if u have any bare wires behind the head unit and tape them up.
Old Oct 10, 2009 | 06:53 PM
polokid69's Avatar
I checked a few of the fuses in the fuse box and they looked ok, checked one marked "ACC Socket", looked fine.
Old Oct 10, 2009 | 06:54 PM
polokid69's Avatar
Sorry, not getting where you say I should look. I have lower panel off, all I see is the white piece for the outside air slider
Old Oct 11, 2009 | 09:14 AM
polokid69's Avatar
I pulled head unit completely out, no bare wires, everything is plugged in solid. Looked around the ac controls, don't see any wires loose, disconnected, damaged but It is hard to get around them to get a really good view. I have the panel above the 12 volt outlet, off and can't see much because the white fresh air slider control takes up most of that space.Only one item behind the HU which is disconnected, a small square connector that appears to have connected to old HU for the IPOD connection that goes to glove box. I'm leaning towards a fuse but with so many to choose from, I'd hate to have to remove and ck each one individually unless someone knows exactly which fuse would handle this. If I can't figure this out, might have to take to dealer but I'm concerned with me changing the HU out, will this void any warranty ? I haven't cut any wires just used radio harness.
Old Oct 11, 2009 | 10:55 AM
reako's Avatar
nahhh....don't take it to the dealer man for a fuse! I was in a situation where I blew out all my rear taillights but ended up finding the right fuse and replacing it myself. Always nice to save a trip to the dealer. If you don't want to pull each fuse to check them (I don't blame you!) you could just go up to the auto parts store and buy a fuse tester.
Old Oct 11, 2009 | 11:05 AM
polokid69's Avatar
You were right, it's a 10 amp fuse in a socket labeled "small light", I replaced it and it blew again, now to find out what is causing it to blow.
Old Oct 11, 2009 | 11:06 AM
polokid69's Avatar
Found the fuse, but when I replaced it, it blew again. Now ned to find out what is shorting it out.
Old Oct 11, 2009 | 12:12 PM
polokid69's Avatar
Success! had two wires from the crutchfield adapter, one orange/white, another, orange. On the radio harness, had an orange/white listed as "Illumination".
The adapter listed orange as lighting, orange/white as dimmer. I had twisted all 3 together.Turns out the dimmer doesn't have a place to connect on new harness so I capped it off and just connected the other two, this time the fuse didn't blow. Now the lights work on the a/c dials.
scarvalho
Oct 26, 2020 11:50 AM
kakrohn
Aug 31, 2020 04:13 PM
sdashia
Jun 19, 2019 08:17 PM
Faoladh
Aug 17, 2017 10:06 AM
Trogdor!
Jun 8, 2010 11:39 AM
