Resetting maintenance minder (specifically tire rotation)
Old Dec 3, 2009 | 10:37 AM
crc294's Avatar
Hi all,
I just got my oil changed for the first time at 10,000 miles. I did not do this at the dealer. The MM oil life gauge is easy to reset, and I did that. However, I also got my tires rotated, and I would like to reset the MM so it doesn't get out of sync with my tire rotation schedule.
Is there any way to reset this without going to the dealer?
Old Dec 3, 2009 | 03:01 PM
Committobefit08's Avatar
See your owners manual page 248.
Reseting the Maintenance Minder will reset the Main Items (A,B) and the sub items (1,2,3,4,5).
Old Dec 3, 2009 | 03:21 PM
JDMxGE8's Avatar
Why do you need to have a MM for tire rotation? Just rotate your tires every other oil change. In my case, I rotate every 6,000 miles.
Old Dec 3, 2009 | 04:02 PM
crc294's Avatar
Well, I'm really anal, and having MM things come up and stay up would probably annoy me.
I read through the manual and didn't see that blurb about reseting. What do you guys think .. do you rely on the MM for anything? If I reset the entire thing after just getting my tires rotated, nothing else will be accurate.
Old Dec 3, 2009 | 04:10 PM
JDMxGE8's Avatar
I usually reset the MM for the oil life after I change my oil, but I don't rely on it. I always change my oil every 3K miles. No matter what % my oil life it. But in the end, it's personal preference. Do as you wish.
Old Dec 3, 2009 | 05:06 PM
Uncle Gary's Avatar
I rotate my tires by observing them, measuring them, and rotating them when they need it. Unlike oil life, tire wear is a parameter I can observe for myself and deal with without a nanny watching over me.
Old Dec 3, 2009 | 05:38 PM
Red 05's Avatar
Well to answer your question cycle to the screen that displays oil life. Hold down that button for like 10 seconds. Release when the screen starts blinking, then hold down again until the blinking stops and the oil life reads 100%. I'd like to think that if I can drive a car I can remember to maintinence, but I guess there's too many people who don't.
Old Dec 3, 2009 | 06:18 PM
hogwylde's Avatar
You sound like me. I don't even like having the head/fog light "minder" lit up on the dash. Can you imagine someone riding up alongside me and thinking there is something wrong with my Fit?!
Old Dec 3, 2009 | 11:42 PM
Codger01's Avatar
I don't mind the fog light reminder, but the headlight one really bugs me...Hello, I can figure out for myself that I have my headlights on!!!!
Old Dec 4, 2009 | 08:09 AM
Uncle Gary's Avatar
Actually, I find the headlight "on" lamp to be useful when I start out at dusk or dawn, since the instrument lights are always "on".
To answer the OP's question. The tire rotation code is, I believe, timed to the oil change, so you can have everything done at once. The owner can only reset the entire maintainance minder, not individual items. Only a service center having the Honda diagnostic scanner can clear individual items from the maintainance minder (at least that's what the service manual tells me).
Old Dec 4, 2009 | 03:25 PM
spreadhead's Avatar
I use the MM for oil change and other maintenance items. I rotate my tires on a mileage schedule as follows: after the first 5K miles on the tires and every 10K miles thereafter. My MM calls for tire rotation on every oil change, I think this is overkill. I've never had a problem using my schedule and I've been doing this since the 70s. This used to be the schedule called for on 70s vintage Fords and it just stuck with me as easy to do and remember.
jlbryan027
14
Jun 30, 2015 12:16 PM
fitchet
Oct 18, 2010 03:23 PM
fitowner10
Jul 13, 2010 01:26 AM
mozarwasagenius
Mar 26, 2009 10:09 AM
wyy183
Dec 2, 2006 03:41 PM
