stinky mildew air when i turn heater on
Old Jan 4, 2010 | 02:26 PM
lewis2k's Avatar
Hello,
my 09 fit has about 10k on the clock, it was used and I've only had it for about 200 miles. I've noticed that when I crank the heat up, there is a smell that comes out from the vents. Its like a old mildew kinda smell and it bugs me. Could this be resolved from changing the air filter under the glove box? thanks in advance! Love the fit forum!
Old Jan 4, 2010 | 04:51 PM
moldy smell usually happens when you have the a/c turned on like if you are in defrost mode in winter time (defrost mode turns on the a/c even though the LED does not light up).
it's possible that your evaporator outlet is blocked. have your dealer take a look if you dont know where to look under the car.
Old Jan 4, 2010 | 05:22 PM
FLEALAMI's Avatar
Replacing the filter might help. A quick fix I've used in the past is to run the A/C and while its running go outside and spray Lysol into the cabin air intake for a while.
Sounds primitive but Lysol will kill any mildew in the ducts and it works.
Good luck.
Flea
Old Jan 4, 2010 | 05:28 PM
hahahaha, that's a smart idea. just dont use one with bleach.
Old Jan 4, 2010 | 06:31 PM
txmatt's Avatar
You can also spray the Lysol (I've used Febreeze as well) into the slot that the filter slides into. This puts it much closer to the heater core box where you're most lilely to have had residual moisture.
Einszett also makes a product specifically for this, called Klima Cleaner, that I'll likely try sometime as well.
1Z Einszett Klima-Cleaner Air Conditioner Treatment
The directions are to spray in a vent and it will run down and drain out the A/C drain. On the Fit, if you do it this way, make sure and remove the HVAC filter or it will get soaked.
henryd1981
39
Jun 6, 2017 11:09 AM
Phoebe70
Apr 15, 2015 02:34 PM
Brain Champagne
Dec 31, 2012 12:10 AM
0Dang
Aug 18, 2011 11:40 AM
2K8SPORT
Jul 29, 2008 05:30 PM
