GE8 Camber recommendations?
Old Oct 13, 2010 | 04:00 PM
strmslvrfit's Avatar
so i just received these camber bolts and there doesn't seem to be a big difference between them and the stock ones. it is a slight bit thinner, so if i install all 4 of them, will i be able to adjust the camber to a certain spec?? or will it be fixed?
Old Oct 14, 2010 | 06:35 PM
MugenAP2's Avatar
It will give you 1.5 to 1.7 degrees not that much, but hey it is something.
Old Oct 14, 2010 | 06:45 PM
Fitabuloussss's Avatar
it doesn't help much. I have them on. I just fendered rolled and that solved my rubbing in the front.
Old Oct 14, 2010 | 07:16 PM
what did you do to fender roll?
Old Oct 14, 2010 | 07:17 PM
arent you dropped on megans?
Old Oct 14, 2010 | 07:21 PM
I had my friend's friend do it. They just take off the wheel bolt this rolling contraption on and use a heat gun to soften up the air and just roll away. Im pretty sure local shops can do it.
Old Oct 11, 2011 | 01:54 AM
ptah626ickness's Avatar
so what bolts was it that gave u guys 1.5 to 1.7 degree? haha i need tat angle
Old Oct 11, 2011 | 08:45 AM
etf's Avatar
etf
Installed SPC Camber bolts on my GE8. We set the front camber @ -1.75 deg. and +.006" toe. Really improved the handling.
Old Dec 9, 2011 | 07:50 AM
Misfyt's Avatar
Was wondering if anyone can link me the website to purchase either Civic SI camber bolts , or spc camber bolts ?
Old Jun 7, 2013 | 01:18 AM
ciref8's Avatar
for those of you when went this route, do you guys have any before and after alignment sheets?
Old Jun 7, 2013 | 10:07 AM
mkane's Avatar
SPC bolts top & bottom
Old Aug 16, 2013 | 02:55 PM
  #32
singhonwheels's Avatar
So i received my ingalls camber bolts from redshift,
i wanted to ask some questions..
The nut on this does not Rotate freely till the end of the bolt, it just jams after rotating a couple of times with my hand.. is it meant to be like this?
Where should i install these, on lower strut or the upper strut?
Should i get my alignment checked before installing these?
(sorry but i m noob with bolts )
Old Aug 16, 2013 | 03:13 PM
  #33
im running spc camber bolts on the front. -1.5
Old Aug 16, 2013 | 03:17 PM
  #34
cjecpa's Avatar
Got mine waiting until I replace the tires figure get them installed and alignment at the same time. Was planning on a -1 and toe at spec. Any thoughts?
Old Aug 16, 2013 | 04:34 PM
  #35
-1.5 will net you better cornering grip. honestly i wanted to do -2, but the range is limited if using only one bolt.
Old Aug 16, 2013 | 06:16 PM
  #36
Wanderer.'s Avatar
Ordered my bolts today finally. I got the Eibach ones which are the same as _____ ones i'm sure, but they were $23 so w/e
Will max them out on install to the best of my ability and run them like that until I get new tires within the next few months and get a legitimate alignment.
SPC says put them in the top hole, but lots of people use them in both, so I don't think it matters all that much. I know mkane actually drives his car hard so he if says using both is safe then I believe him.
http://www.spcperformance.com/compon...AFrom&to=USATo
Old Aug 17, 2013 | 01:41 AM
  #37
lowkeymods's Avatar
I run -1 camber up front which is plenty of clearance with a fender roll for 17x7's.
Just remember guys, the more - camber you run, the less time you'll get to enjoy your tires.
Old Aug 19, 2013 | 02:43 PM
  #38
ANybody ^
Old Aug 19, 2013 | 03:02 PM
  #39
pig_pit's Avatar
Are u on coilover or springs?
Old Aug 19, 2013 | 03:05 PM
  #40
SPC Performance - SPC Alignment - Specialty Products Company
sounds good. i too used it on the top hole.
