***Official GE Parts/Weight List***
Old Jul 17, 2010 | 09:22 PM
  #81
555sexydrive's Avatar
I've had the J's Ti on order for almost a month. 2 of the 3 pieces, will order front pipe later on. Nothing else at this time.
Old Jul 23, 2010 | 05:51 AM
  #82
Lyon[Nightroad]'s Avatar
A/C is about 20 lbs at the most . Judging by curb weight of canada fit with and without a/c.
Old Jul 23, 2010 | 07:39 AM
  #83
blackndecker's Avatar
20 lbs is not insignificant...especially once you get down to around 2000 lbs. That's 1.0% of the car's weight. I wonder how much airbag system weighs?
Old Jul 23, 2010 | 12:54 PM
  #84
ThEvil0nE's Avatar
Rear seat belt assembly (driver and passenger side)
*note:
1. this is only for the belt assembly and without the female harness which is on the back seats
2. two (one each side) floor mount bolts are not weighed as I retained them to minimize debris getting into the frame. Will be coming off after I obtain plugs.
4.75 lbs
Old Jul 23, 2010 | 01:47 PM
  #85
Originally Posted by blackndecker
20 lbs is not insignificant...especially once you get down to around 2000 lbs. That's 10% of the car's weight. I wonder how much airbag system weighs?
Think you meant to say 1%.
Old Jul 23, 2010 | 02:10 PM
  #86
Yeah...uhhh.....whoops. Math > Me
Wish I'd could shed 10% of the car's weight by relocating the battery.
Old Jul 23, 2010 | 02:11 PM
  #87
*note:
Thanks man. ****GE Official Weight**** thread has been updated, props, and +rep given.
Old Oct 6, 2010 | 02:09 PM
  #88
First page updated with airbag weights courtesy of 555sexydrive.
Old Mar 9, 2011 | 06:17 PM
  #89
EpilepticFit's Avatar
Hey, here is an article about why saving weight on your car is important:
http://http://www.bbc.co.uk/news/magazine-12664047
There is more to going fast than losing weight, but going fast is the best reason.
Old Jun 17, 2011 | 05:23 PM
  #90
Goobers's Avatar
Okay, so the other day, I rotated my tires... and on that day I decided to weigh them and the original setup (I had bought a scale from Walmart to do this).
My flat tire weighed in at 34.8 lbs.
My non-flat stock setup came in at 35 lbs.
My new setup weighed 32.6 lbs
Incidentally, the Enkei + Conti comes out to 0.1 lb lighter than specs for them combined (I assume it's just a rounding error and manufacturing variance on the tires).
But it makes me wonder... how could my stock weigh 35 lbs? Compared to the first page listing it at 39 lbs. Or more specifically, weigh only 2.5 lbs more than the new setup. Granted, I haven't pumped any air into them since I took them off 3 months ago... but just air alone can't account for FOUR lbs!
The Dunlops weigh about 18 lbs according to Tirerack, which means the wheels weigh less than 17 lbs.
I have 12k miles worth of wear on the tires (appears to be half its tread life). So, can missing half its tread life, plus a couple of natural PSI loss over 3 months account for 4 lbs?
For some slight reference, I weighed myself... Dressed in jeans, t-shirt and sandals (and my bag of crap)... I weighed about 197, which is a hair more than all the other scales I've used (potbellys and where ever I found a free one). So, I think the scale is mostly correct.
Old Jun 17, 2011 | 10:19 PM
  #91
Thanks for the update. Were you using a spring loaded scale? This is why I always tried to use digital packing scales.
I have two thoughts on why the weights are off:
1. One or the other of the scales are off (either yours or the OP)
2. Spring loaded scales have an optimal range where they are most accurate (i.e. 50-250 lbs). Anything outside of this range will under or over compress the spring resulting in inaccurate weights.
I think the second scenario is probably the most likely but both could e contributing in this scenario. I always hauled my stuff up to UPS to weigh them. It would be awesome if you could haul the wheels up to UPS and take a picture of the wheel on the scale.
Old Jun 17, 2011 | 11:55 PM
  #92
Goobers's Avatar
The scale is supposedly a "high tech"ish one... using four load cells on each corner.
It's actually just a body weight scale. Walmart.com: Health o meter Oil Rubbed Chrome and Silver Scale: Home Medical
it's strange.
Old Jun 18, 2011 | 10:35 AM
  #93
wontfit's Avatar
Just remember folks, it's not how much you lose, it's where you take it off. Balance the fit.
Old Jun 18, 2011 | 11:27 PM
  #94
What do you mean balanced? A "performance oriented" FWD car should be as light as possible in the rear...unless you mean balanced side to side which is possible only with height adjustable coilovers.
50/50 balance would be retarded in a FWD car...you'd have ZERO traction when you press the gas as the weight shifts rearward. Even 60/40 is a little too much weight in the rear IMO if you want a tail happy FWD car.
Old Jun 21, 2011 | 01:02 AM
  #95
wontfit's Avatar
^^^ that's only part true. as i said, it's about balance.I'm not referring to the chassis balance, i meant that as in not going over board in removing weight from a given area and not in another. as a side note, removing weight from the front WILL increase handling as it will save on your tires, weight=heat= understeer. i speak from SCCA experience. only a noob removes/mods his car w/o contemplating first how it affects the balance of the car.
Old Jun 21, 2011 | 01:05 AM
  #96
205s in the front 195s in the back, wat'chu know about that?
Old Jun 21, 2011 | 01:15 AM
  #97
wontfit's Avatar
that helps, but not enough, you'd need something wider up front and skinnies for the rear to get a noticable improvment in oversteer. like 215's (if you can tuck em') and 185's...
btw lyon, i'm from SO ILL , near benton(though i live in oregon now.) whereabouts are ya? also, i've enjoyed your build thread.
Old Jul 18, 2011 | 12:28 AM
  #98
whitefitsport's Avatar
What about the windshield washer fluid? I took it out of my S2000 and saved around 8 pounds!
Old Sep 14, 2011 | 10:50 PM
  #99
tuning g's Avatar
wow the battery is 22lbs
Old Sep 14, 2011 | 10:51 PM
  #100
tuning g's Avatar
cool list subscribed
Z062FIT
Racing
Jul 16, 2018 06:12 PM
Elephantman
May 25, 2011 12:15 PM
Bounty Hunter
Apr 22, 2011 10:29 PM
Gooshin
Jul 17, 2010 08:12 PM
blackndecker
22
May 21, 2010 07:26 AM
