Grounding improvement for the Fit
Old May 25, 2010 | 08:01 AM
Lyon[Nightroad]'s Avatar
Originally Posted by hayden
Every car these days seems to need a grounding mod. I'm not electrician, but why would there be 1 ohm of resistance in there? Surely these companies know there efforts to keep costs and weight down have created this condition. Maybe it isn't a critical part of the system? I would think that it is. I'm not sure I've ever seen a car not make more power, or smoother power and better idle with a grounding mod. What's up Honda?
Honda has provided a ~90 amp alternator, there is nothing stock in this vehicle that comes close to needing that much power. 1 ohm of resistance will not affect normal operation of the vehicle and as I mentioned that resistance does not apply to the plugs.
Old May 25, 2010 | 08:26 AM
dewthedew's Avatar
Yeah but the stock grounds are terrible..
Old May 25, 2010 | 08:40 AM
deleonl1's Avatar
Anyone find a good spot to attach the cable on an automatic?
Old May 25, 2010 | 08:45 AM
Even if the stock ground was 16 gauge and 2 feet long (which it is not) . The theoretical resistance of the wire should only be 0.0082 and even if all 90 amps are running through that wire there should only be a volltage drop of 0.738 volts. Call them terrible but they aren't affecting anything unless you have junk in the trunk (amps and subs). Considering the voltage would still be around 13.2 volts ...
lol nvm
I see what you did there...
Anyway, I was wrong. At 1ohm the vehicle would be INOPERABLE as there would be a ~93 volt drop at full load, impossible.
The key thing with grounds is that length is a critical factor. At these 1-2 foot lengths the difference between 0awg and even 16awg is minimal for the non subwoofer inclined. The only time awg becomes a big concern is for that 16 foot wire going to your trunk.
Old May 25, 2010 | 08:59 AM
dewthedew's Avatar
The car works just fine with stock grounds.. but If silly things like lights dimming when idling with a/c on or when touching an acc switch, or even slow starts, revs bouncing, etc, etc. Than improving grounds will deff make a difference to you. If you dont care about any of that then "its not broken done fix it".
Old May 25, 2010 | 09:01 AM
I've done the big 3 with 0 awg (well grounding strap is 0awg, I used 4awg for the others) and I still dim when a/c kicks in. Don't think it's a grounding issue. Anyway my main point was that the OP had not upgraded the Grounding Strap or Battery to Chassis wire so it wouldn't improve any of those things even if they were caused by a bad ground. Also I was concerned about grounding the battery directly to the engine. I only upgraded for the sake of my sound system, which I have noticed a big improvement with. I have noticed no difference in any factory component, lights even still dim when I close a window, but they don't dim when I hit anyting but the most extreme of bass notes.
Old May 25, 2010 | 10:22 AM
hayden's Avatar
Yeah, that info helps all this make more sense. I just wouldn't believe that, with all the intense R&D and high tech features that goes into a car these days, that a minor gauge upgrade in the wire was not on the list of critical components. Some cars really respond to it though (+whp, not just smoothing the graph), so I am still a little confused on why that is the case, but your experience and knowledge on the subject is valuable. It's such an inexpensive fix, but I guess the bar minimum is satisfactory for most components in a car - understandably.
So, has anyone noticed a change in the way the car drives?
Old May 25, 2010 | 04:09 PM
Roger's Fit's Avatar
Originally Posted by annunC8
RF, you rock, man! You keep coming up with those cool and resourceful mods and fixes... I'll keep reading and implementing them! We can do this sorta' thing all day if you like!
Question... do you think any of the electrical grounding kits such as HKS' Circle Earth Kit or others, are any good, or would be any better than this grounding fix? I'm curious as to whether they would provide an even better ground... albeit they're a A LOT more expensive than yours.
The link:
Project Honda Fit Exhaust Parts Shot Photo (I have no clue as to why the link states an exhaust part... that's goofy)
Some of the peeps from tuner mags seem to almost swear by these things. Some have even claimed an actual increase in hp from "perfected" grounding.
You seem to be the creative auto fix-it man! Just curious about your opinion on the matter. I guess your post (the grounding fix) proves there's at least some need for items such as these. If it's worth the cost, well, I suppose that's an entirely different matter.
Thanks again for the latest fix.
Oh and, BTW... do you think the rear fender applique is worth the money Honda wants for it? I notice you have one installed on your Fit. A couple of people here said they appear to be complete, or near complete, crap. I was going to get one for my Fit until a forum guy said he thought it was cheaply made. Of course, that was only his opinion... no right or wrong here I suppose.
Thanks
Ok. To answer your questions:
The electrical grounding kits cannot hurt, but are overkill most of the time, and especially for this car. I prefer something more low key.
The applique works fine, is just a piece of non skid. You cut one cheaper and with the same results as what Honda sells.
Old May 25, 2010 | 04:10 PM
Originally Posted by Uncle Gary
The first day I owned the Fit, I looked at that wimpy ground cable to the radiator support and said to myself, "WTF!!!!" Every other car I've owned or worked on had a ground directly to the alternator/engine and a secondary ground to the body. I am so doing this mod! In fact, I may do this to the Harley-Davidson. It might not cure the intermittant starting trouble, but "it coudn't hurt".
Plus rep for this one.
Is the intermittent starting issue with the Fit or Harley?
Old May 25, 2010 | 04:29 PM
True, but the issue with most cars is sometimes the grounding wire, and the rest of the time the grounding attachments. Corrosion and oxidation at the connection points affect these.
Yes, you can clean these. I'm still under the impression that there should be a ground from the battery to the block, to assist with the biggest load, the starter.
I have a grounding story, while extreme, accentuates the point that grounds should err on the side of more and larger. While driving some friends around in a vehicle many many moons ago, I turned on the headlights, and the temperature gage pegged high. The guy, drunk, relayed that this was normal operation for the gage....
Later on that evening, while driving on the interstate, the engine cut out and finally stopped. No indication of any issue. When the hood was popped, it was discovered that there was a hole in the radiator hose. Of course, with the temp gage pegged high (later found to be caused by a bad ground), you could not detect this flaw.
I also had a car that the dash lights would dim any time you turned on the blinkers. That was fixed by a battery to body ground cable. For that particular car and many others, the alternator is incapable of outputting a large supply at idle.
I am a somewhat sensitive to grounds, and as such, am willing to spend $3.44 to improve a actual, not a perceived measurement, knowing that the measurable outcome may be difficult to detect, because the logic behind it is sound and based on science.
The issue with lights that dim at idle when starting large loads such as the AC clutch is in most part, the battery. The internal resistance of the battery prohibits such a large current outlay. Buy a bigger or better battery. Other contributing issues are body grounds and alternator regulator response time.
Old May 25, 2010 | 05:11 PM
Selden's Avatar
Thanks for providing evidence. Although I can think of no downside to this mod, is there one? Seems like a very easy upgrade.
Old May 25, 2010 | 05:16 PM
  #32
None that I am aware of, but Lyon mentioned that he seemed to remember there being a downside. Maybe a little time will jog his memory.
Old May 25, 2010 | 08:35 PM
  #33
MS Paint ftw!
Here is the stock setup:
Here, in red, is the wire you installed:
Here, in red, are the wires that are normally upgraded to improve grounding and reduce overall resistance (The Big 3)
Here, is the reason why you don't need an engine to battery wire if you decide to updrade the other wires:
The wires with blue arrows are the grounding path for your accessories. It is a longer path than just upgrading the grounding strap.
You could also upgrade the grounding strap but then you would be paying to add 4 wires instead of 3 and still getting the same performance as 3.
(Thickness/1) + Distance = Resistance
Old May 25, 2010 | 08:46 PM
  #34
Old May 25, 2010 | 09:40 PM
  #35
bmxman's Avatar
hmm.. 2 FF members claiming opposite results. I'm guessing the only true answer is to test your own car as they may have different readings. I personally trust Honda and will leave my Fit as is. Curiosity did get the best of me and I tested my car and had the same results as applemacfit. I do have a friend that also has a GE next time he's over I'll take reading and see if there is a difference.
Old May 25, 2010 | 10:19 PM
  #36
Daemione's Avatar
Absolutely, measure your own car before bothering. I saw a surprising amount of resistance on my GD (like I said, .6 ohms from the negative battery terminal to the alternator body, and between .4 and .6 ohms at others points on the engine & chassis).
With only one relatively thin gauge chassis ground, it's not hard to imagine it being perfectly fine in 2007 when applemacfit tested his, but performance starting to degrade 3 and a half years later.
Old May 25, 2010 | 11:54 PM
  #37
Aye, after 3 years you are definetly going to want to clean all of your connection points.
Old May 26, 2010 | 10:25 AM
  #38
annunC8's Avatar
MS Paint ftw!
Lol... MS Paint is in serious need of grounding!
Results after grounding? Adobe Photoshop!
Old May 26, 2010 | 01:19 PM
  #39
beangrower's Avatar
SO... at worst...there's is no downside to this...right? besides being out $3.50. No negative impacts on performance, right?
Old May 26, 2010 | 03:21 PM
  #40
As far as I could find there should be no downside so thumbs up to the OP. I would just encourage anyone upgrading to also do the big3
